34Ford
North Carolina
Just bought a '08 King Ranch with 124k miles. Changed the plugs today, Whew, glad it has the one piece plugs. Hallelujah.
Gruz7
North Smithfield, RI
Awesome! I love that look. So you didn't have to make any of the brake lines longer of the transmission shift cable? What did you use to do your lift?
Nope with the 1.5” blocks he filler neck was good, steering linkage was good, brake/fuel/tranny/shifter lines were all good, there was a little bit tightening on some of them and a few grounds but still enough slack for driving. The rear tow hitch rubs against the back bumper cover a little bit as well but not too bad. And like I said the only really needing changing is the fan shroud I took about 2” off the bottom of the shroud
Gruz7
And to do the actual lift I used all hand tools and a torque wrench (60 ft/lbs) and then some 4x4 wood blocks and 2 floor jacks to lift the body off one side at a time
lvcjt702
Lost Wages
You dont happen to have the adjustable pedals, do you?
Sent from my SM-G935P using Tapatalk
scoot0073
Georgia
Gruz.. what body lift did u use ?
Any links..
1.5 doesn't sound like much but I'm guessing you probably can tell it getting in.
I'm doing this been pondering on it all summer but is there a reason why you went with the 1.5 and not 2" ?
Guessing that at the 2" it might would involve having to change or extend things..
Looks good brother [emoji3]
Gruz7
Any links..
Yeah I have a few friends that did the 3” and needed to extend some thing here and there and I wanted to stay away from that, typically with 4runners, cruisers and other overland type trucks I saw that they were all going for basically a 1.5” body lift (probably to make I‎t easier to get things off the roof). So I did some quick guesstimate measuring and I‎t seemed like I‎t would work well for me. You can definitely tell the difference in person and I now think 37s should clear okay-ish. But I just bought 3” blocks from Zone and had them cut in half and I got All grade 8 hardware with some big washers/red loctite/proper torque specs. And I’ve had I‎t pretty fast around corners, had it in a few trails and have had zero issues at all. A 2” lift would be the absolute MAX as far as lines/wires/steering/fuel neck/bumpers go IMO... even the 1.5” kind of pushes everything a bit but I checked and I have slack everywhere and everything is proper. Fan shroud is only thing that needs adjustment.
Gruz7
I do have adjustable pedals and I believe they work fine but haven’t tried pressing the button in a few weeks. (or “post-body lift”) lol
scoot0073
Georgia
Sorry what is Zone ? Auto Zone ?
I wanna get these I'm gonna try the 2" and c what all needs to be done. Cutting the fan shroud isn't no problem and if I need to trim the rear bumper also bc of the receiver then that not a problem either.
The extended brake lines shouldn't be hard to find.and the steering knuckle might be unless it's universal with a f150 or may have to have one made..
But I definitely doing this.
Thanks brother
scoot0073
Georgia
3" blocks as in blocks on a real leaf spring axl to lift ?
Sorry for all the questions man..
I'm definitely doing this.
Heck I still got my WAM Front Bumper sitting on a pallet at the house.. just been to darn busy at work to get it started..
Gruz7
Haha nice I’m ordering my WAM bumper at the end of the month but no they are specifically body lift blocks, just google 3” x 3” body lift blocks and those are the ones, you’ll need 8 of them and then 2 of the 2” x 3” high blocks
scoot0073
Georgia
Ok Kool I'll Google that at lunch.
Thanks brother..
scoot0073
Georgia
This it ?
$4.00 each 2" tall 3" wide and I need 8 of them
Gruz7
This it ?
Yeah so if you’re gonna go with a 2” body lift then you need (8) 2” tall 3” wide blocks and (2) 2” tall 2” wide blocks. And that looks like them to me
scoot0073
Georgia
Heck yeah sounds good thanks man gonna get them ordered
scoot0073
Georgia
Sweet bro let me know if you need any pointers you can pm me and I’ll give you my number I could walk you through any of I‎t
Thanks I will if needed but can't be no more harder than the 3" leveling kit..hahah
I'm currently trying to find extended brake lines jus n case but tried a couple places and nothing for Expedition so maybe I need for a f150..
I'm probably gonna have to take mine and compare them to find what will work..
