ExpeditionAndy
Gruz7,
That looks great. Did you have to replace anything to get that high of a lift?
Nope basically just cutting a little off the fan shroudGruz7,
Awesome! I love that look. So you didn't have to make any of the brake lines longer of the transmission shift cable? What did you use to do your lift?Nope basically just cutting a little off the fan shroud
Nope with the 1.5” blocks he filler neck was good, steering linkage was good, brake/fuel/tranny/shifter lines were all good, there was a little bit tightening on some of them and a few grounds but still enough slack for driving. The rear tow hitch rubs against the back bumper cover a little bit as well but not too bad. And like I said the only really needing changing is the fan shroud I took about 2” off the bottom of the shroudAwesome! I love that look. So you didn't have to make any of the brake lines longer of the transmission shift cable? What did you use to do your lift?
And to do the actual lift I used all hand tools and a torque wrench (60 ft/lbs) and then some 4x4 wood blocks and 2 floor jacks to lift the body off one side at a timeAwesome! I love that look. So you didn't have to make any of the brake lines longer of the transmission shift cable? What did you use to do your lift?
You dont happen to have the adjustable pedals, do you?And to do the actual lift I used all hand tools and a torque wrench (60 ft/lbs) and then some 4x4 wood blocks and 2 floor jacks to lift the body off one side at a time
Gruz.. what body lift did u use ?And to do the actual lift I used all hand tools and a torque wrench (60 ft/lbs) and then some 4x4 wood blocks and 2 floor jacks to lift the body off one side at a time
Yeah I have a few friends that did the 3” and needed to extend some thing here and there and I wanted to stay away from that, typically with 4runners, cruisers and other overland type trucks I saw that they were all going for basically a 1.5” body lift (probably to make It easier to get things off the roof). So I did some quick guesstimate measuring and It seemed like It would work well for me. You can definitely tell the difference in person and I now think 37s should clear okay-ish. But I just bought 3” blocks from Zone and had them cut in half and I got All grade 8 hardware with some big washers/red loctite/proper torque specs. And I’ve had It pretty fast around corners, had it in a few trails and have had zero issues at all. A 2” lift would be the absolute MAX as far as lines/wires/steering/fuel neck/bumpers go IMO... even the 1.5” kind of pushes everything a bit but I checked and I have slack everywhere and everything is proper. Fan shroud is only thing that needs adjustment.Gruz.. what body lift did u use ?
Any links..
1.5 doesn't sound like much but I'm guessing you probably can tell it getting in.
I'm doing this been pondering on it all summer but is there a reason why you went with the 1.5 and not 2" ?
Guessing that at the 2" it might would involve having to change or extend things..
Looks good brother [emoji3]
I do have adjustable pedals and I believe they work fine but haven’t tried pressing the button in a few weeks. (or “post-body lift”) lolYou dont happen to have the adjustable pedals, do you?
Sent from my SM-G935P using Tapatalk
Sorry what is Zone ? Auto Zone ?Yeah I have a few friends that did the 3” and needed to extend some thing here and there and I wanted to stay away from that, typically with 4runners, cruisers and other overland type trucks I saw that they were all going for basically a 1.5” body lift (probably to make It easier to get things off the roof). So I did some quick guesstimate measuring and It seemed like It would work well for me. You can definitely tell the difference in person and I now think 37s should clear okay-ish. But I just bought 3” blocks from Zone and had them cut in half and I got All grade 8 hardware with some big washers/red loctite/proper torque specs. And I’ve had It pretty fast around corners, had it in a few trails and have had zero issues at all. A 2” lift would be the absolute MAX as far as lines/wires/steering/fuel neck/bumpers go IMO... even the 1.5” kind of pushes everything a bit but I checked and I have slack everywhere and everything is proper. Fan shroud is only thing that needs adjustment.
3" blocks as in blocks on a real leaf spring axl to lift ?Yeah I have a few friends that did the 3” and needed to extend some thing here and there and I wanted to stay away from that, typically with 4runners, cruisers and other overland type trucks I saw that they were all going for basically a 1.5” body lift (probably to make It easier to get things off the roof). So I did some quick guesstimate measuring and It seemed like It would work well for me. You can definitely tell the difference in person and I now think 37s should clear okay-ish. But I just bought 3” blocks from Zone and had them cut in half and I got All grade 8 hardware with some big washers/red loctite/proper torque specs. And I’ve had It pretty fast around corners, had it in a few trails and have had zero issues at all. A 2” lift would be the absolute MAX as far as lines/wires/steering/fuel neck/bumpers go IMO... even the 1.5” kind of pushes everything a bit but I checked and I have slack everywhere and everything is proper. Fan shroud is only thing that needs adjustment.
Haha nice I’m ordering my WAM bumper at the end of the month but no they are specifically body lift blocks, just google 3” x 3” body lift blocks and those are the ones, you’ll need 8 of them and then 2 of the 2” x 3” high blocks3" blocks as in blocks on a real leaf spring axl to lift ?
Sorry for all the questions man..
I'm definitely doing this.
Heck I still got my WAM Front Bumper sitting on a pallet at the house.. just been to darn busy at work to get it started..
Ok Kool I'll Google that at lunch.Haha nice I’m ordering my WAM bumper at the end of the month but no they are specifically body lift blocks, just google 3” x 3” body lift blocks and those are the ones, you’ll need 8 of them and then 2 of the 2” x 3” high blocks
This it ?Haha nice I’m ordering my WAM bumper at the end of the month but no they are specifically body lift blocks, just google 3” x 3” body lift blocks and those are the ones, you’ll need 8 of them and then 2 of the 2” x 3” high blocks
Yeah so if you’re gonna go with a 2” body lift then you need (8) 2” tall 3” wide blocks and (2) 2” tall 2” wide blocks. And that looks like them to meThis it ?
$4.00 each 2" tall 3" wide and I need 8 of them![]()
Heck yeah sounds good thanks man gonna get them orderedYeah so if you’re gonna go with a 2” body lift then you need (8) 2” tall 3” wide blocks and (2) 2” tall 2” wide blocks. And that looks like them to me
Sweet bro let me know if you need any pointers you can pm me and I’ll give you my number I could walk you through any of ItHeck yeah sounds good thanks man gonna get them ordered
Thanks I will if needed but can't be no more harder than the 3" leveling kit..hahahSweet bro let me know if you need any pointers you can pm me and I’ll give you my number I could walk you through any of It
