chuck s
- Joined
- Dec 20, 2006
- Posts
- 1,990
- Reaction score
- 753
Nice that the firmware will jump from 1.0 to 2.3 in one move!
-- Chuck
-- Chuck
I've not had any problems except not having the file to upload back to ford.First glitch after updating to 2.3 -- Push speaker button on steering wheel, error message appears on screen: Voice Recognition Not Ready
Two reboots as instructed. Still "Voice Recognition Not Ready".Power and Next Track button, press and hold. System will reboot. After the screen shows back up and your radio works, do it again. 2nd time it comes back up your voice recognition should work. Yell if that does not work, there are a few more things we can try.
Ford sent me an email asking to confirm my Sync update on their website. Their link to their website does not work. There is no file on my USB to upload anyway.
Performed master reset with onscreen instructions. Added phone and wifi back. It remembered my radio station presets, thankfully. Rebooted twice (power/FF buttons). The only difference now is that it asks me whether I want to receive updates via wifi and asks me to reconnect to wifi after each reboot. It didn't do that before the master reset.
Still, Voice Recognition Not Ready!
With that said, connect to your home WiFi, and check for updates. That will cause it to report to Ford. It will accomplish the same thing as the USB file.
Mystery solved. This is the logical reason Ford knows I have the latest firmware.
-- Chuck
Reinstallation worked. I just checked after 30' and "installation complete" was on my screen. Removed drive. Turned off car. Restarted. Voice recognition works.
New file in the SyncMyRide folder on the flash drive: Sync_WV3J...7.xml. Another poster said they could not find the file to upload to Ford. It is in that folder. I almost missed it, until I thought to open the folder.
Thanks Loki. Not sure why it hung up the first time. Today I moved all files to trash and started with a fresh download from Ford.
Monday she gets custom Traxda 2.25" lift (front and back) and BFG AT/TA/KO2's, one inch taller (60's rather than 55's). No more bottoming out in the sand!
Did you change your tires and wheels or did you run stock with the Ready Lift?Glad to help!
Our 15 had the Ready Lift 3/2 lift on it. I have the kit for the 17 sitting in the Garage. Just need to do it. Loved it on the 15!!!
I'm still considering doing this but I don't want to do the work so I'll have to find someone here in the area that does lifts. I think I'll keep my stock tires and then when they wear out I could go up in size. My speedometer is off by 2 MPH so I could go up in size a little without messing with the computer.Kept wheels, and ran a 275/60R20, basically a 33. Slightly larger than stock.
Going to run a 295/60/R20 this time around most likely.
Loki, any other ideas before I take her to the dealer? I still don't have voice recognition.Power and Next Track button, press and hold. System will reboot. After the screen shows back up and your radio works, do it again. 2nd time it comes back up your voice recognition should work. Yell if that does not work, there are a few more things we can try.
