Sneaky Pete
Ordered and successfully installed an aftermarket remote start, that uses my original Ford Keys to start the truck. Just push the door lock button 3 X's. Ordered it through MyPushCart.com.
http://shop.mypushcart.com/vehicle-remote-starters/
After calling them directly and asking, they discovered that the 2014 F150 would work with my 2016 Expedition, EVO-FORT1. Total cost, including shipping $119.95. Simple easy to install. Most of it is plug and play with only two wires that you need to strip back without cutting, I did solder method here to connect the CAN High and the CAN Low. They give you a very good Tip Sheet that you can download in a PDF as well as 2 YouTube videos showing step by step. They are located in AZ so if you need tech support make sure you know that they are M-F Arizona Time. All in all, I am very pleased and would recommend it, especially after my Ford dealership said it would be $750 and they would be giving me another key fob, something I did not want. Only issue with the entire set up is that you must have both sets of keys!!!! Curious if anyone else has heard or used this company for a remote starter or other products. LMK & Good Luck if you try
