old codger
Does anyone know if the 2013 Expedition headlights will physically fit a 2017 Expedition. I have seen several aftermarket headlights for years up to the 2013 but nothing after that. Thanks!
I want to thank all of you for replying. If any body finds any aftermarket replacements please post or let me know. The thing I don't like about the factory headlights is you can not adjust the high beam if you replace the bulb with an LED. Also, I am going to see if I can find a way to install an LED strip on the bottom as channel looks empty. Thanks Again!
You talking about under the light housing between that and the bumper?I want to thank all of you for replying. If any body finds any aftermarket replacements please post or let me know. The thing I don't like about the factory headlights is you can not adjust the high beam if you replace the bulb with an LED. Also, I am going to see if I can find a way to install an LED strip on the bottom as channel looks empty. Thanks Again!
This is an earlier gen 3 but I filled the empty area with a profile pivot switchback strip. Parking light is white then switches to Amber when the blinker is turned on. It look blueish in the pic but it's actually pure white
Is that one of yours?
Andy
Did you modify the headlights? I don't recall mine light up there on that thin strip.That it is. Still loving them months later.
Okay I'll look for it.I have a full bi-xenon projector retrofit setup, the LED strip was added during the build process to light up that strip.
I had a thread about them a few months ago (November I think).
