Anyone know what this vacuum component is?
kcexplorer
Missouri
Hi there, I recently posted in regard to a likley vaccum leak on my 2003 expy xlt. I was getting p0171 and p0174 codes. I checked the PCV elbow and it looks good, however I did find leaks here. With the left hose disconnected (see picture) the truck ran and sounded okay. I took a broken piece of the connector to connect it for the time being. I would like to find out what this piece is called so i can get the elbows replaced. Thanks for your help.
Hamfisted
Ft Lauderdale
It's a check valve. One inlet / two outlets. Do you have a junk yard in your town ? Or are you just talking about the rubber hoses ?
K
kcexplorer
Missouri
Thanks. I replaced the hoses, but idk about the valve. I have a vacuum leak and problems with HVAC system only blowing through the defrost (possibly due to loss of vaccum). Any way to check if this check valve is bad? If it is, does anyone know if it would cause a leak?
Thanks
Plati
I'm think that might be the one that disintegrated on mine and caused air to only come out my defrost instead of panel & floor. I replaced the hoses and it instantly fixed air blowing inside cabin. 2003 EXPY Hard to tell exactly without taking computer out to engine compartment.
Air always comes out my defrosters lately no matter what, doesn’t stop unless I shut the fan off. The wacky thing is every other mode works perfect but it still comes out the defrost. I’ve learned to live with it.
Plati
Yes, same connection ... I replaced a hose ... had to remove battery to get to it.
I just took a lousy picture but that fixed the defrost only problem.
K
kcexplorer
Missouri
Great. I have plenty of hose so I will pull the battery and inspect the hose tomorrow. Thanks so much!
dlyoung1
Central Texas
Let me jump in and bump the post with a related issue. Just finished doing an a/c evac and recharge on the wife's '03 XLT and I have a similar but not quite identical problem. The entire climate system works just fine, EXCEPT a/c on the MAX (Recirc) setting. Nice, cool air comes out of the dash vents at idle, but smoothly transitions to the defrost vents when I hit the accelerator. Soon as I take my foot off the gas, it transitions back to dash vents. I traced the exact same line as the original poster above, replaced a splice that seemed to have "collapsed" at the check valve / tee, but no joy on the problem. The end of that line is the vacuum reservoir tank next to the battery. Could I have a cracked line under there that ONLY affects the recirc door circuit, or is it more like somewhere in the cabin under the dash (closer to the door mechanism)? Thanks in advance!
Bain64
You still have a vacuum leak. Sorry I can't help pinpoint further but keep chasing vacuum lines
dlyoung1
Central Texas
Yep. The leaky component will hold sufficient vacuum at idle to keep the recirc door closed, but not under increased "vacuum demand". Looking up under the dash around the air box this evening.
US
I had a similar problem and found the vacuum hose on the heater hose valve had come off.
Sent from my LG-LS998 using Tapatalk
