LED Turn Signals?
gixer2000
Retrofit or Bust
Massachusetts
So I’m assuming the led mirror turn signals are not getting 12v? If they are why not tap into those?
Gixer, if you can sort out how to do this properly so there’s no phantom blinking of the brake lights etc when turn signals are used...I really would love the info. I really want to make this happen...
I'm sure I could figure it out it's just how your bcm would feel about it. My sjb isn't as sensitive as a bcm. I'm on vacation all this week but when I finish the retro this will be my next project. Yours could probably be done with programming from the navigator blinker program and maybe a harness swap. I'd need to locate both schematics to be sure though
gixer2000
Retrofit or Bust
Massachusetts
Actually looking again I actually could rob from the mirrors. They do get 12v so all I would need to do is drop a relay with the coil powered off the mirror blinkers and cut the blinker circuit for the rear tail some place before the brake ties in. Good idea Muddy!
gixer2000
Retrofit or Bust
Massachusetts
The toughest part is still splitting the blinker from the stop. They are both controlled by the sjb so if I cut out the rear I'm technically cutting out the front also unless I open up the sjb and disconnect the blinker side of the mosfet for just the rear. May hit a junk yard for an sjb
Muddy Bean
Interesting...so the junction box is where it’s at....I need to study this more because I don’t fully grasp the way our lighting is wired in these trucks. My 2015 is so complicated it amazes me...
outsideDad
US
Hi, I'd like to do some led upgrades to my 2016 EL limited,
Here's what I think I've learned from this thread.
For my rear brake/signal I need a 7443 not a 3057.
Then use FORscan to stop the hyper flash? And that requires a doggle?
How difficult is Forscan to use?
Would I be able to make the LEDs in the mirrors sequential?
I've already purchased the LEDs for the reverse.
Thanks in advance for any help.
Sent from my TM785M3 using Tapatalk
Flexpedition
midwest
I'm not sure where I missed you on that Tekonsha 118158 box.
Input is what you have now and output delivers what you are looking for.
gixer2000
Retrofit or Bust
Massachusetts
Apparently when I looked it up the other night I looked up the wrong part number because this could work. Not sure how I screwed that up but whatever this may do it
Muddy Bean
When I’ve used this exact box as intended (input and output) it has issues on my truck. When using turn signals, it flashes both tail lights. Brake lights work, and turn signals work when brakes are applied but when running lights are on, both tails flash when a turn signal is on. So there’s something wonky with how this box works. I don’t know if it would work better in the application we are discussing which basically is reversing its intended use...but I’d be willing to try.
Flexpedition
midwest
Understood. Maybe the 3rd brake lamp circuit can become the source that feeds your housings.
Muddy Bean
Good idea! That’s perfect. Third brake light feeds to brake housings, mirror turn signals feed the turn signal housings and boom.
gixer2000
Retrofit or Bust
Massachusetts
Yeah that works but involves building an entire harness for the brakes and blinker circuits. I was looking to make it happen easily without running wire everywhere. But it's probably the easiest option.
Muddy Bean
Don’t stop looking because if you figure out a cleaner way to do it I’m absolutely interested. Because I tow my truck 15,000 miles a year behind my tour bus, and my tour bus has separate turns and brakes, it really would be best for me to make my truck the same way. Plus, we sometimes park on on ramps for the night with semi trucks since we are 65 feet long and I have a switch that activates my hazards on full brightness but not blink for extra visibility when parked for the night.
Axle Folly
Seattle Area
I have been working on a plan, yet to be executed. If you can help me poke holes in it before I get too far into tearing into my vehicle, I'd appreciate it!
My plan is to get a tail light converter module (either Tekonsha 118158 or Curt 56196) and stuff it in the tailgate lift access opening, conveniently located behind the driver's-side tail light assembly. This gets me separate brake and turn signals.
Then, I would enlarge the hole for the reverse light (921) and install a Amber/White switchback (7444na). I'd wire the reverse light circuit to the white, and the turn signals to the amber.
Since I don't necessarily trust all of the added connections or the magic converter box, I would drill another hole in the tail light assembly for that little 921 bulb, and wire that to the existing stop/turn circuit that I tapped the magic converter box off of. My hope is that this does a couple things: 1. Avoids hyperflash/bulb out message with new LED turn signal, as the incandescent bulb would be used, 2. Offers some redundancy should the converter box fail, and 3. Would help force me to check that the LED bulbs were still working at least as frequently as my 921 bulbs burnt out!
Muddy Bean
Axle,
You have some good ideas there for sure. I especially like the switchback for reverse LED idea and may try to experiment with that myself a bit. I’m still not 100% convinced that the converter box will work the way we are hoping because of my experience with that exact box doing weird stuff. I’m also not sure how you’re going to wire the switchback LED but I’m super interested to watch the process. Someone here might be more familiar with how a switchback works (wiring wise) and could chime in.
deweysmith
Montreal, QC
Switchback is pretty simple, I thought I explained it earlier in this thread, but it might have been a different one. EDIT: I kinda did over on post #35.
Basically, there are two circuits in the vehicle that go to the turn signal harness. 4 contacts on the bulb and two filaments inside the bulb, one is a low (15W?) draw and one is a high (30W?) draw. When parking lamps are on, the BCM grounds the low circuit, closing it and lighting up the smaller filament for dim amber lights. When the signal is flashing, it repeatedly grounds the other circuit, causing that circuit to close and the larger filament to glow much brighter. As far as I know there is no situation where they are both powered.
Switchback LEDs take advantage of this by having two separate circuits in them with two sets of LEDs. They are the same brightness, usually, because they contain the same number of the same LED chips, just in different colors. The white LEDs are on the same pins in the bulb harness as the smaller filament in the incandescent lamp, and the amber LEDs are on the same pins as the larger filament.
They may do something clever where all LEDs are on the same circuit, but one color is wired in the opposite polarity as the other, and since LEDs only light up when powered in the correct polarity, only one will light up at once, but the operating principle is the same.
This is also how the drop-in brake LEDs work, because your brake/tail lights are wired exactly the same, pretty much. I think it might power both filaments for brakes, but again the principle is the same. The only difference for the LEDs is one circuit is wired to light up half the LEDs on the bulb, the other lights all of them.
old codger
Jefferson City
I just installed led bulbs in front turn lights. I eleiminated the hyper flash in forscan but the passenger bulb is still hyperflashing though the drivers side is not. whasup??
Axle Folly
Seattle Area
A bit tardy on the reply OC, but I was reading just today that some flasher relays need a load to cycle. So, if you defeated the hyperflash electronically in Forscan, you may still need resistors for the mechanics of the flasher relay to function.
Dewey: I looked into how the stock bulbs are wired as I'm in the home stretch of getting my amber turn signals put together. I put a test light on my brake/turn socket over the weekend. What I saw was that both filaments are energized whenever the bright side is activated. So, not knowing if the switchback LED is going to be looking for power on both legs when I'm in turn signal mode, I plan to have diodes on hand that I can splice in to energize the white side of the switchback LED without feeding the reverse light on the other side of the vehicle if need be. I will certainly let everyone know how it turns out.
gixer2000
Retrofit or Bust
Massachusetts
I have a 2011, where are good locations to mount the resistors?
Use forscan to turn off bulb out warning for the rear and put the resistors behind the headlight for the front. Make sure you mount them to the body of the car to dissipate heat
Fred Moore
Knightdale, NC
The 3157 bulb does not work in the 2015-2017 Expeditions.
2017 Expedition King Ranch:
Please help me understand what you mean by the Sylvania 3157R will not work.
I installed them and with the exception of hyperflash, they seem to work fine--very bright. Alas, I reverted back to original bulbs because even with resistors installed and all connections metered for continuity, I still have a bad case of hyperflash--drives me nuts. The resistors are mounted with 2 self-taping screws into sheet metal.
I have not attempted any alterations via FORScan as I don't have the connective hardware.
One question: Do I have to change out & add resistors to the front signals to effect this change?
