Here are 3 parts you will need regardless of which HSW you decide on:
Wiring harness - you could build your own (and maybe save a few $), or contact Luke (
[email protected]) and he will build you a professional wire harness for around $200...ensure you mention this harness is for the Expedition (it saves you money and makes it easier to connect). (My next post will explain more on the wire harness.)
Heated Steering Wheel Module - Ford made it easy (for a change) to select a HSWM...they are all the same. If the HSWM looks like the one below, then you should be fine. (You DO NOT need the mounting bracket that comes with some HSWM...we do not have the mounting holes, so you can just tuck the HSWM under the dash and zip-tie it in place.) A good used HSWM costs as low as $20, and a new module from Tasca Ford is around $40...choose your preference. The only difference between using a new or used is the FORScan programming required...if new, you will need to program the module (easy to do-I'll post instruction later when I discuss FORScan settings) and the old will already be programmed, you just change the settings you want.
Splice connectors - pick up at an auto parts store for around $3-$4...makes the 3 splices you will need very easy and secure.
