Muddy Bean
Wow, huge props to you for doing this! Another really awesome write up on this forum. Very very cool.
Since the 2018+ models may have such a module, as the HSW is now available for these newer trucks, it certainly sounds like a good idea to include that option for Expy vehicles in FORScan.![]()
I searched and watched ebay for several weeks before I finally had all the parts I needed for the install. These are the parts you will need along with the range of reasonable costs I've seen on ebay...you may be able to find a local connection that can beat these prices, so be patient and resourceful.
Heated Steering Wheel: $40-$150
Airbag for HSW: $230-$350
HSW Module: $25-$100
HSW Clockspring: $100-$150
Wiring Harness: $200-$250
Wiring Splice Connectors: $5 (or less)
17LimitedExpy, thank you SO much for sharing your experience here. Two questions: (1) about the parts list above, can you share the PN and source for the pins you had to add at clock spring connection? (2) You mention as one of the drawbacks that cruise now works like old version where one click does both resume and cancel. Would you mind clarifying - what I was used to in my 08 Nav was that cancel on the steering wheel would completely disable my cruise "session" and I would have to set speed again to re-enable. The only way to suspend/ "cancel" was to tap the brake pedal. With your new set-up, if you hit the resume/ cancel button to suspend cruise, does it pick back up again at your previous set point if you hit it again to resume? Thanks again for your contributions here.
Here ya go, I hope this helps answer your questions:
1. I do no have the part numbers, but if you go to the F-150 Forum and do a search, a thread on there has the part numbers listed. I used the mentioned wiring harness which already had the two pins ready to plug into the back of the clockspring connector...made it very easy.
2. On the original 17 Expy steering wheel, the button for cruise control 'Resume/Cancel' is one button...when the cruise is engaged/on, if you push the 'Resume/Cancel' button - then cruise is cancelled, push the button again and cruise will resume. No need to 'set' cruise again, the resume button picks up the speed you last set. It sounds like on your 08 your cancel button was actually an 'off' function. Does this help clarify?
