Bummer
1111ExpyEL1111
NW Wisc.
I tried to get the fogs to stay on with the high beams. I'm running (properly aimed) HID's all around. I thought it would be as easy as running a power line form the high beam wire to the power line on the fogs.
Nope!
The computer started doing weird thing with the high beams. Hard to describe. I disconnected everything and will try again if I can figure something out.
Any ideas out there?
1111ExpyEL1111
NW Wisc.
Revert back to the original wiring, visit the forscan section here, buy a $30 obd 2 connector from Amazon, turn on bambi mode. It will work 100%
Are you kidding me? It's this easy? I spent a half a day on Saturday wiring this all up. Can you paste a link 2A Amazon OBD connector that you know works please?
Muddy Bean
Yep. That easy. Many of us on here have done this using ForScan. Take some time and search the site and learn about ForScan before making changes to your truck. Here’s a link to the ODB connector I used to get you started.
ScanTool OBDLink MX Bluetooth: Professional Grade OBD-II Automotive Scan Tool for Windows and Android – DIY Car and Truck Data and Diagnostics https://www.amazon.com/dp/B006NZTZLQ/ref=cm_sw_r_cp_api_PLg4BbC88WVHQ
1111ExpyEL1111
NW Wisc.
Thanks Muddy I just ordered the scanner. I'll check out the Forscan threads to learn how to do it.
mquick5
Buckeye Country
And that's why you should include your year make and model to your signature, or at the least in your post. I know you already said you order'd but here's a link to the adapter I purchased.
VINT-TT55502 ELM327 USB modified For FOSCAN ELMconfig FOCCCUS HS-CAN / MS-CAN
mquick5
Buckeye Country
1111ExpyEL1111
NW Wisc.
Munkiebunz3
Soviet Monica, Kommiefornia
gixer2000
Retrofit or Bust
Massachusetts
Based on what I'm seeing here I spent way too much money on this ODB tool.
That's the one that's recommended from the programmers of forscan. Others work, some are buggy, some don't work. This is the best option.
As for Bambi mode I'm very confident it can not be enabled on your year. Everyone else posting has a 15+ from what I can tell.
I was unaware our fogs turned off with the high beams, learn some thing new every day. Curious why you want the fogs to stay on? I’d think you’d have to figure out how ford actually cuts the fogs out and remove that. Forscan has never really interested me, doesn’t seem very useful on our 3rd gens. I’m not a computer guru however, many more knowledgeable members here as far as that goes. The computers seem pretty locked up on these vehicles and unless you have access to ford computers you can’t tamper much.....which I’m sure ford did purposely, lots of people out there who don’t know what they are doing..... my 2 cents.
1111ExpyEL1111
NW Wisc.
If I knew for sure I could do it I would keep it and make the adjustment. But nobody seems to know for sure and that's okay. Everybody, thanks for your help!
