My 04 expy is on the road now, new intake,water pump, knock sensor, fuel injector o-rings, spark plugs, oil change , antifreeze...a lot of cleaning... After all done starting the truck and see everything work as it should,no leaks no abnormal sound "PRICELESS"[emoji16]
Now the other issue my door ajar light is always on. I read and see alot about it, many ways to fix it but figuring out which door is the problem was the important part. One YouTube video help me out and I would like to share with you guys.
Start your truck and over 10mph going stop somewhere that an other person can open the doors or trunk for you. Every time open only one door. The one that is not activate your doom lights is the problem door or like in my case trunk [emoji16] . After determining the problem switch you can replace or bypass it as you wish. I prefer fixing it right. So I will replace my swich on the trunk lid. Lock assembly. Does anyone have the part number for that? Thanks a bunch in advance.
Sent from my SM-N960U1 using Tapatalk
