Why are 1st generation 5.4 Expeditions so reliable?
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
i have 184,*** and to date I’ve only done wear items except for replacing a cracked intake which I learned is made of plastic for my year.
This truck has been very reliable in fact driving from Chicago to central Florida next week without hesitation. I tow my boat (3000lbs total wt) like it’s not there and have cruised at 70-75mph in long flat stretches of open hwy with it in tow.
My theory and I’d like your opinions on this is that first this truck doesn’t have much in the way of modern technology. I’ve garage kept it’s whole life except for one bad winter when I kept my old bimmer in the garage cause I couldn’t find storage that year.
I think that garage keeping vs harsh elements here plus my OCD on maintenance has served me and this truck well.
Reading the F-150 forums and the newer generation expy posts here it is discouraging to see the myriad of systems failures mainly due to new technologies and electronics, sprinkled in with several common defects for each power plant and generation.
Could it be these 1st gens are the most reliable Ford trucks generally?
hammerg26
North Georgia
202 on mine.
Need to replace #1 COP.
Been solid for the most part.
nycnftm
Atlanta
HA! I tell my friends it cost me $500 each time I drive it. I rode in 3 tow trucks this year and spent over $2000 in the past 3 months.
Vancouver Bob
Vancouver, WA
I've got around 210K on my 2nd gen with no issues... except for a couple AC fixes (expansion valve and evaporator).
1955moose
You hit on the head with simplicity. These are fairly complex motors compared to the simple pushrod motor it replaced. And yes the later 05 on up variable timing motors added weak gaskets, weak oil pumps, and all kinds of garbage that was replaced, just to squeak out 40 more hp . A few tweaks on the 03 motor could Ihave got them there. Easiest would have break out the boring bar. A bump to 360 ci and a few tweaks would get you there. A fuel pump driver module on 05/06 that were mounted outboard near a spare tire. Really, you can't see a problem with exposed connections getting plummeted with water and snow not causing issues? Except for a group of boneheads under developing the spark plug threads, and another idiot thinking that soldered fuel pump relays on 03 should last longer than the old pop in ones, the first gens, and early second gens would be like their 5.8/351 replacement bullet proof. But alas, they never listen to the ghost of Hank Ford, the original model T is fine the way it is. If the wackos in Washington would stop trying to get a 6,000 pound SUV to approach the mileage of a Prius, these failures wouldn't happen. Wouldn't have guys/girls here with 2018 3.5 turbos melting down with less than 50k on them. On top of that they have to have oil Labs like Blackstone do blood tests just so their warranty vehicle gets fixed. Well theirs my rant for Friday, I wish all here a Merry Christmas, and be safe travelling this week coming up.
Plati
I also thumb my nose at a lot of the modern tech and features adding to less reliability. But, my 2003 XLT (which always lived outside and is none the worse for that) has its own inherent "could fail at any point" concerns. Wheels hubs, battery, hoses, alternator, water pump, brake and fuel lines, electrical connections, a/c, blowers, window regulators, snake belt idlers, suspension components, cats, cops, etc etc. Get in front of that with regular maintenance and inspections but can't predict and avoid many things.
That's why I only drive that beast local to home and use a newer Expy for my long trips. Just tipping the scale of problem avoidance in my favor.
guspech750
Western Burbs outside of Chicago
My 2002 F250 with its 5.4 has been ridiculously reliable. 215,000 miles and it’s not broke down once.
I truly believe in the simplicity of the 5.4 and no technology in my pick up at all. Even with buying my 2017 Expedition. I still drive my F250 all around and up to Wisconsin. I still love it.
Trainmaster
Old School Member
Rockaway Beach, NY
My 2000 was an excellent truck. Never left me stranded. More simple vehicle with fewer things to go wrong. The 2008 has been great so far also.
1955moose
I remember back in 1976, I bought my first "real" home stereo. I bought one of the best sounding receivers of the day, a Pacific Stereo house brand. But the thing I remember telling my salesman Allan, who was so knowledgeable, and cool to deal with, I said I want a simple record turntable that sounded great, and only had return. Didn't want the needle dragging at the end of an album. Cueing it myself was no biggie. That turn table lasted 35 years. I sold it in 2010, all it ever needed was a new belt. Simplicity is usually a long laster. I've always believed that. If I had my way, I'd probably build a Expedition with a 1970's Bored out 351, with all the techie things to make it all gel, and run cleaner/quieter. A motor, that didn't have to worry about silly things like cam phasers, cam guides that discentregate, etc. Wonder when Ford or Toyota, is going to invent a motor that doesn't need a timing chain/belt, and all the ancillary pieces to make it work. When you think about it, our SUVs are a more complex version of the original single piston version of old Henry's original way back in 1903. Makes you wonder what's next? I'm always amazed how they get 400 hp, and lower emissions than just 10 years before. Their will come a day when we'll be like Japan, make you get rid of your vehicle at 50k, or at least put in an engine. Can you imagine putting in a motor here every 4 years? Could happen sooner than you think.
Plati
What's next is using microwave ignition instead of spark plugs
johnboneske
My 97 was unbreakable... Except for normal stuff, all I ever did was put an alternator on it, sold it with about 285k on the odometer. My 03 is a different story, its been a money pit, but still love it. 215k in it now
Eagle 71
Nebraska
Moose, your post is spot-on. I wish somehow I could forward your post to the whizkids in Dearborn and the chuckleheads in the DOE, either of whom don't know their arse from a cylinder head, so they could use your info to somehow try to fix this issue.
Boostedbus
Sent from my N9131 using.
Tapatalk
Sorry but Government ain’t getting my guns or my engines! At least not without a major rebellion! I just might start building a Mad Max car now to prep for the future. LOL!
Machete
Machete
Illinois
I love this ^^. BUT...you just killed a sale for Ford because I’m in the market for another truck/vehicle as I’m handing this one down to my son who travels regionally for hockey through all kinds of bad weather.
I’m not sure what my next vehicle will be truck or SUV but from reading the forums I’m not keen on driving a twin turbo close to red line to get torque and power nor am I interested in replacing turbos or doing cam phasers after my first hundo thousand miles.
The only Ford that qualifies for me so far is a 5.0 F 150. I was considering 2016/17 Expy. Not anymore after reading about all the issues w direct injection and catch cans, cam phasers, cam chains etc.
Trainmaster
Old School Member
Rockaway Beach, NY
You would think that the cams could be run by synchronous electric motors. That would eliminate the stupid oil-driven phasers, thirty inch chains and those oil-gate solenoids. When they burn out, just install new ones and time them electrically. Or better yet, just actuate each valve with a solenoid.
1955moose
That sound great. Only problem I see is a solenoid acting up, due to Chinese or Mexico origins. If they used quality parts, highly unlikely, might be an option. I think all this is a moot point, as in probably about by 2040, none of the big 3, if their around, will be even using internal cumbustion engines. I think all electric, or a electric/ fusion type motor will probably be the norm of the day. Batteries that can go a 500 miles range will be standard. Charging stations will replace fuel, with a quick 10 minute charge up that gets you back a full charge.
Idahokid
Coeur D Alene
I had a 1989 F-150 4x4 5.0 give me 272,000 miles.
I bought this 1998 Expedition with 131,000 on it six years ago and now has 187,000.I drive it sainly and change the oil and keep it pretty clean.I hade the diff fluids changed yesterday and the hopping and jumping in tight turns went away when I’m in four wheel drive.The binding was getting bad but it’s smooth now and love driving it again.It has a traction lock diff so I told the tech don’t forget the friction modifier.Its big,heavy and stable in the snow.
johnboneske
I don't know why you say that? Like GM is any better, or Dodge? They all have their issues... I
No members online now.
Landsbutter
