Anyone monitoring Trans Temp with ODB2 reader app?
Black
Black
Kentucky
Such a learning curve with this app. Just have to fool around with stuff until you find what you are trying to do.
I have the tire pressure display but can’t figure out how to change the units to PSI from inHg
Moderator
Settings, Preferences, Units, The Pressure setting at the top...
Black
Black
Kentucky
Thanks. You likely saved me 30 more minutes of fooling around or so.
Also anytime I need to adjust other.
Moderator
Already been there! That’s what we are all here for right? Try to help others and prevent them from making the mistakes we might have already made!
Black
Black
Kentucky
So far it has been just trial and error picking and choosing changing and looking.
So many options and parameters it makes ones head spin.
I am not looking to do much with it just a few helpful dash boards and once they are set will just be turn it on and roll.
chuck s
In my '07 5.4 V8 the parameter was Trans Temp 2. There was/is apparently more than one to choose from.
I monitored trans temp in this truck when towing for 10 years and only one (1) time did it exceed 240°F and that was on a brutal day in heavy traffic and only for a few minutes. It was usually ambient air temperature plus 100°F -- e.g. - on an 80° day the transmission ran 180°. Thermostat didn't open until 145° or so. The transmission in this truck locked up immediately after shifting.
I also monitored engine coolant which flat-lined at 200°F even in the Pennsylvania mountains regardless of the season. Cylinder temperature fluctuated more often than coolant but typically peaked no higher than the 215° range.
-- Chuck
JimmyM
Boston, MA
I use a cheap ELM327 and Torque Pro. One of the "Trans Temp" PIDs that came with it and the Ford extended PIDs was just a mimic of the coolant temp. I created a custom "gauge" using a trans temp PID I found online. I too was using an old android phone. Works great. You can read/clear DTCs, create all sorts of dashboards. The cheap-o OBDII adapter I bought only has access to HSCAN. There are hacks to allow you to add a switch to access MSCAN, but it's a manual process. The OBDLink MX can switch between HSCAN and MSCAN using a software command in TorquePro. Tire pressures are on the MSCAN in the 3rd gens I believe.
Moderator
Correct. Extended PID.
Get what you pay for. I have tried about 10 adapters through the past few years. The MX+ is the best so far at doing it all. All device types, all protocols, and good software support.
JimmyM
Boston, MA
I just bought an MX+. Do you know what the extended PIDs are for the TPMS on the MS-CAN?
Moderator
You have one free upgrade in the OBDLink app, use it for your year PIDs. Then you can choose it from the list in the BCM. I can hook up later and see if I can get the PID Address.
Black
Black
Kentucky
I use an
I use an iPhone the other day the app had an update and in the update notes it stated that all MX+ devices now get all the upgrades for free.
I am still learning on this thing so I have not have tried to mess with a second vehicle yet.
Moderator
I use an
Nice, I’ll have to check it out. Sucks, cause I paid for one...in addition to my free one.
JimmyM
Boston, MA
I figured out what I have to do between Torque and the MX (Not MX+) to get access to the MS-CAN bus for specific PIDs (TPMS). (Diagnostic Start & Stop commands)
To read the trans temp I had to specify 221624 as the PID and then "7e1" as the OBD Header. I see that the Ford specific free importable PIDs also now have a transmission temp PID that has the same settings. So you don't have to create a new one yourself.
I created a "Towing dashboard" in Torque that displays, coolant & trans temps, transmission gear, and fuel economy. I'll be adding the TPMS gauges when I get the MX.
