ManUpOrShutUp
This gauge is plugged in all the time?
I know you weren't asking me, but I wanted to add some info. I have the UltraGauge MX and it's plugged in all the time, but when it's first connected it has to be plugged in with the ignition in the on (not run) position and should be removed before reconnecting the battery (if you're disconnecting to work on truck, etc.). If you connect the battery with it plugged in the truck will throw codes and run rough until the codes are cleared and the truck is restarted.
