Gary D White
Ok try to make this short as possible. Car was running rough, then it wouldn't start. I put a new fuel filter and pump on. She'd start, as soon as put into gear it'd diet. So I decided it wouldn't hurt to change the spark plugs n ait filter. Oh boy, changing the plugs was a *****. I cleaned up the injectors, COP's, throttle body and housing behind the throttle body .Won't start at all now. Does sound the same, has a lower sound, slower. Bought a multimeter,checked ignition coils they're all right around 1.0/0.9 on the primary, on the secondary I believe it's around 5.4 with the kind that is just a spring, the ones with the prong at the end of the spring is about 0.5/0.7 higher. Attempting to see if they're making spark I took COP's out n put everything else in place. Hooking each coil up the no5 connector I'm not seeing any spark. Just plugged it in and shoved a spark plugs and in the boot .nothing. what am I missing, where do I need to look now? IAC? I cleaned it along with everything else. EHR pressure feedback sensor? EGR valve control switch? Voltage regulator? PCM? Bad alternator? Blown fuse? Bad relay?
