Should I replace the radiator as preventative maintenance? It too is original. If I’m gonna do the coolant hoses and thermostat why not go ahead and replace the radiator w new OEM?
There are problems with the "shotgun" approach of changing parts for preventative maintenance, then taking that long ride. Without a careful analysis old the parts' deterioration, you often risk damage to the few remaining original parts.
Twenty-year-old car: You change hoses, radiator, water pump. Lots of mung is cleaned out. Now the pressure and cooling pressure's restored. Wham! That crappy old heater core is pushed to its limit and water's pouring out from under the dash. And you're a thousand miles from nowhere.
Remember what happened when you changed the varnished tranny fluid in that 100,000 mile, fifteen year old Chrysler? The seals blew.
You are also putting a lot of bets on new parts, which are at least sometimes defective.
And as cars get older, the quality of replacement parts decline. Often only the crappiest manufacturers are left making parts for a vehicle. Finding 20 year OEM is like finding hens' teeth. More likely, you'll only be able to get Chinese junk.
I'd minimize my parts changing to things I knew were in poor condition and I'd do it a month or two before the long trip. This way any new problems could pose themselves before I'm en route and new troubles would be minimized.
