2000 Expy XLT Vibration issue
RunningonExpy
First time poster here...already scanned through the forum looking for my exact issue and I couldn't find an exact solution so here's the problem...
Have a 2000 Expedition 5.4L Triton with the 4r100 tranny code verified. I've had a constant vibration issue that also initially had a hesitation/bucking issue when accelerating quickly (felt like the COP/plugs change problem that has been well documented in this and other forums). Changed the COP's and a bad plug even though several readers showed no codes and never got a check engine light, vibration/hesitation on acceleration problem stayed the same (slight improvement but nothing worth celebrating after the changeout).
Kept on looking through this forum and found the 104 fuse trick and pulled it, all of a sudden the acceleration hesitation/bucking problem went away BUT the vibration has continued. Had my tires rebalanced today and all of them were way out of balance but after balancing them the ride is a bit smoother but the vibration continues.
The vibration is as follows: After accelerating to about 20 miles an hour vibration starts without the steering wheel shaking (feels like something below the floorboard but not at the wheels), vibration gets worse at 40mph and continues higher in RPM's until 55 where once again it gets worse. At no point over 20 does the vibration go away, just diminishes at certain speeds and above 55 gets even more intolerable. Since I seemed to resolve the hesitation/bucking issue (probably something to do with the front AWD drivetrain?) what could the vibration be? During the rebalancing I looked under the front end and everything seemed in place; mechanic said the rear u-joint was a little worn but nothing major.
Ideas? Since it's an older expy I would like to try to attack the exact issue instead of throwing money down the drain with "exploratory" diagnostics that may not get anywhere. Love the power, not the expense lol!
I can try the brown wire mod to shut off AWD permanently if necessary, but I don't think that will get rid of the vibration.
Thanks for any hints!
R
RunningonExpy
Edit: Jumped the gun to test a theory...clipped the brown wire (not modded, just clipped so the AWD would go to 2WD) and put the 104 fuse back in...vibration still there, however switching manually to 4H did not produce the hesitation/bucking like before, and none in 2WD with the fuse in. No improvement on the vibration problem though (although backing up in 4H sounded like a lot of creaking/crackling somewhere in the front end). Any closer to a solid idea?
R
RunningonExpy
Which part of the drive train? Should I focus on the front drive shaft or the rear one? Any idea of which u joint tends to go out first?
Trainmaster
Old School Member
Rockaway Beach, NY
I'm with Machete. Check your universal joints. I had a 2000, and I replaced them several times over the 250,000 miles it was on the road. Sometimes you can check them in the car. Raise the front wheels and twist and shake the driveshaft, paying attention to play in the u-joints. Then do the same with the rear wheels and driveshaft.
It's probably best to just remove the driveshaft and see if the joints move smoothy. Sometimes just shaking it won't tell you anything. If I recall, you need a 12-point socket. You don't say where you are, so I can't tell you how difficult it will be. Rust plays a part in all of this. The shaft comes right out -- the rear one has an annoying guard that has to come off and one of the bolts is rather hidden and fights with you.
When you take the shaft(s) out, mark the position with chalk, as it should go back in indexed the same as it came out.
Pressing in new u-joints can be a bear. Don't buy Chinese ones, or you'll be doing it again in three months. You can try using a c-clamp but again depending on rust, but if you monkey-hammer it you can bend the ears on the driveshaft. If it fights, take the driveshaft to a driveline place and let them replace them.
Here's a tool, but you can use a regular socket too:
https://www.amazon.com/CTA-Tools-4340-Drive-Socket/dp/B008FJXA9G
or Sunex 212ZUMDL, which appears to be better quality.
Plati
Could there be a bad tire … problem with a belt in a tire?
I'm not sure about this but sometimes the frequency of a vibration can indicate its source. If you could associate the frequency with the period of rotation of the tires that might be a clue. Also, could put the spare on one wheel at a time to eliminate a tire/wheel issue … but that's a lot of effort.
Killer Ride
US
It could be your tires. I had a problem with mine once and it wound up being a seriously blemished tire. But if the guy working on the truck said Ujoint was suspect I would start there
R
RunningonExpy
Great ideas everyone...I'm going to focus in on the u-joints with a buddy who's a mechanic and see if there's too much play on the front one first, where the vibrating is coming from. Could a bad u-joint(s) also cause the AWD bucking/hesitation or would that be a separate issue? Since I cut the brown wire to only enter 4HI manually I didn't get any bucking either from 2WD or 4HI. I'll post what I find later this week when I get them changed out.
Thanks for the quick replies and ideas!
Machete
My Rig. 2000 EB 4x4 5.4L
Illinois
Bucking and hesitation doesn’t make me think of u joints. That sounds like an engage/disengage issue w differential excluding electrical issues. But hard to diagnose this way.
Have mechanic check it out. Sounds like a system problem not just a worn part.
R
RunningonExpy
Would it matter in the long run as long as I use it in 2WD? I live in an area where I would most likely never use 4WD for anything, and using the brown wire mod to force 2WD (or manually engaging 4WD) seems to prevent the issue from occurring. From what I've read on the forums changing to 2WD from the default A4WD has no long term effects. I really don't have the resources to fix the issue other than the u joints and driveshaft at the moment, and I really don't need A4WD in my location. Can anyone confirm that disabling A4WD long term will eventually break down the system irreparably or just maintain the status quo indefinitely? I will definitely get the u joints checked/changed and/or check/repair the drive train, but trying to diagnose the A4WD system might be more than I can afford...
BTW, you guys are awesome!!
TobyU
I pulled the fuse for the transfer case in out 2000 when we got it in 2011. Been fine ever since. I did just use 4wd a month or two ago after putting fuse in to pull a large stump/tree around. It worked fine.
Yupster Dog
Moderator
My sister has a 04 Explorer Sports Trac and basically the same thing was happening. went thru tires, u-joints, differentials, transmission and it was still there. Finally took it to the dealer and it ended up being the transfer case engage motor. it still worked but was going bad and was the cause of the problem. I am not saying that this is your problem but I would think it's worth looking into.
R
RunningonExpy
Yeah, I'll get that checked out too after the u joints. Did she have a vibration along with the bucking/slipping? A vibration even when it was in 2WD?
1955moose
The transfer case motor seems to be the go to item on the first and early second gen models. I have a 2000, that I run without the fuse connected, and have no issues. Unfortunately you can't just pull the front CV shafts and run it up the block. Your shop if their worth their salt, should be able to sort out your vibes.
R
RunningonExpy
Thanks!
juan214
Stoughton, MA.
So you pulled the fuse for the front differential "AWD" and your problem went away. The fuse goes back in and no problem again, but now the turn bucking started the old issue will return eventually. The issues will even act up when hitting the brakes and it seems to act like the ABS system thinks the truck is in a skid situation. Check out the below whether or not it continues your option.
Cheapest Check:
Before you go spending any more money or go to a shop. Especially if your ABS light is intermediately illuminating. If you got metric Allen keys. Pull your front wheels. Turn the knuckle to get access to the front abs sensor. Use caution and do not break or strip the bolt. Inspect the sensor for wear. The sensor should show no signs of wear at all. Even if the sensor shows the least amount wear not even visible to the naked eye. If it does the hub assembly is worn. Even a front end check with tires on will not be felt or have visible movement. The sensor is not making the right contact to the ring to communicate to the PCM. It is kicking the front differential off and on causing the "vibration". Replace both front hubs more than likely they have never been replaced.
The Fix:
Its an easy fix for any DIYer with the tools. Depending on your finances it's at about $70 for two new hubs with ABS sensors installed. Highly recommend two new AWD ONLY hub seals while your their $25 for both.
Additional Notes:
Check both half shafts for (movement) wear. Inspect all four CV boots for tears or grease leakage. Now would be the time to replace them as to replace either hub you will need to do the same procedures.
Check your Ball joint while here for wear as well.
The rest of the front end if needed can be done anytime as none of the replacement procedures are repeated.
Good Luck
Dustin Gebhardt
Tulsa, OK
My 2001 vibrated like you described until I replaced the u-joints. 3 different sizes required for my year, if I recall. I ended up going to multiple parts stores and Ford to get them all. Several years later, my 4R100 dropped the intermediate sprag. The transmission shop did something to the u-joints, the vibration came back, so I replaced the u-joints again. Each time the vibration went away.
1955moose
If the tranny shop didn't mark and reinstall shafts in same spot, a vibration will be felt. Happened to me years back on my 82 mustang 5.0. replaced front and rear u joints, but didn't mark the front, where it separates from the yoke. What happened was I got a nasty vibration above 50 mph. Drove that way for about 2 weeks, pulled the shaft, popped out front u joint, rotated it 180 degrees, vibration totally went away. Driveshafts are like tires, they need to be balanced. My guess is whoever owned your SUV, messed with one of the shafts. Well that's what happened to me at least.
juan214
Stoughton, MA.
100%
