Illuminated stainless steel Sill Plates.
Jon1985
Cinnaminson NJ
Hello everyone I was looking at different types of accessories you can buy for the Expedition on the official ford parts website I happen to come across these stainless steel door sill plates 8L1Z-78132A08-A that illuminates for the front doors. I thought these would be very cool and unique if I installed them on my Limited Expedition. Has anyone here ever did this install or knows how difficult Is it to install them? They look like they have a connector on the end of the wires maybe all Expedition’s has the Connections ready to go for these? Just curious because depends where you buy them they are not cheap . Any information would be helpful thanks !
Geargambler
Poconos PA
I didn't know that these existed. Pretty neat! It would be awesome if the connector was already there and you just needed to plug them in, but I dont think that is the case.
I found this video - I cant imagine it would be a much different install.
Trainmaster
Old School Member
Rockaway Beach, NY
The Ford OEM ones are top quality. They install with double sided tape and wire into the fuse box. You run the lead up the weatherstripping and under the dash. The come on with the dome lights when you open the door.
gixer2000
Retrofit or Bust
Massachusetts
Do you have them or seen them installed? I'd love to see some pics of the ford one's.
Trainmaster
Old School Member
Rockaway Beach, NY
Plenty are shown with a Google illustration search. They are the same ones as the Escape, Edge and most other Fords, with a different word on them of course. I've seen them on an Explorer and they look good.
There's a pair on ebay for $50 but the guy says the leads are only a few inches long, which means they have been cut or something. He said they have "filaments coming out of them," whatever that means. But they still have the unused tape on them so they haven't been installed. Sounds like your kind of deal Gixer.
gixer2000
Retrofit or Bust
Massachusetts
I love projects! I'll take a look
Thanks
Trainmaster
Old School Member
Rockaway Beach, NY
I know you like these projects as do I. Some of the OEM panels have multiple leads that can be switched/combined to change the illumination color. I couldn't find a manual for these Expedition ones, so I don't know if they have two leads or many. If the wiring on the ones he's selling has been all goobered up with the insulation pulled off it, you'll have a challenge. Price is right.
rexster314
Texas gulf coast
I installed these sill plates shortly after getting our new 2012 KR. There's no plug and play connectors. You have to find the proper wires in the wire bundle coming out of the fuse box on the passenger side kick panel. I posted pictures but the image hosting web site went out of business. I may still have them. All in all, took about 3 hours as I measured twice and cut once.
Geargambler
Poconos PA
so they are definitely stick-on?
I think a few users said they had the ford ones installed and they sucked. I recall hearing the lighting was blue and not white as advertised and that they stratched and got ruined easily. I posted a thread on this last year and everyone who bought them hated them so I stayed away.
J
Jon1985
Cinnaminson NJ
Sorry I haven’t been on thanks for all the replies. I have to do more research I guess before I go ahead and buy these or anything I have to look at the wires on the passenger-side like rexster314 said I just don’t wanna screw anything up these very cool glad I came across them and other think their cool too!
svfetter
Louisville, KY
I put the factory sills in my 2011 and have been very happy with them. However, They will scratch easy. I believe they are alum and not Stainless. Easy to put in.
I have show car Mustangs so I am very picky. I cover them with tape if I have to take truck in for service. If you do get a minor scratch I have sanded them out with 300 to 600 grade sand paper only in the direction of the grain.
J
Jon1985
Cinnaminson NJ
So I bought the sill Plates from eBay in a Previous post someone else mentioned about them I went for it . They are brand new only thing I had to buy was the LED’s that snap into the harness on them which were 5mm led’s also bought them on eBay also pre-wired for 12 volts Applications . Only thing I’m waiting for to come in is the wire spool , shrink tubing , quick snap connects to run and make all the connections. I’m probably just going to tap into the front dome lights wiring. Also if anyone is wondering the LED’s light up fibers to light up the expedition letters it’s not a led light Strip .
star-art
Pacific Northwest
Aha! They're fiber optic! Very cool! BTW, all you need to do to change the color is use a different LED or tint the end of the fibers where the LED is placed. You can also use an RGB LED if you have a controller for it and then you can change the color on the fly.
PS Be sure NOT to buy these used if the fibers have been clipped near the sill plates. Even if you attempt to repair and extend the fibers, they will loose much of their light transmission at the break/joint.
Muddy Bean
Those actually are tasteful! I like them!
rexster314
Texas gulf coast
Mine are still going after almost 7 years. They get scuffed some, but judicious use of a nylon pot scrubber will dress them back up
