VIN decoding & options/packages
Adieu
SoCal
Interesting stuff...
Benji-Man,
Very interesting. I "thought" I had the No Boundaries Pkg but the list doesn't say so specifically. I still think that's what I have. Instead, mine says "(-) Version Packages" at the location where your listing says "No Boundaries". Mine was built six months before yours. Otherwise, it looks like we have just about the exact same options.
Primary Features
Build Date:
**16.01.2001
Vehicle Line:
**C-MAX 2007-2010
Body Style:
**4 Door Wagon
Version:
**Ford Series
Engine:
**5.4L Modular SOHC V8
Transmission:
**E4OD(4R100)
Drive:
**LHD 4WD (FTD)
Emission:
**With 49 State Emission Requirements
Air Conditioning:
**HD Manual Air Conditioning
Paint:
**Oxford White
Minor Features
• *Medium Graphite Interior
• *119"/3023MM Wheelbase
• *XLT
• *(-) Version Packages
• *Michigan Plant Built
• *U.S. Sales
• *Less Special Equipment Package
• *With Convenience Group
• *Less Military Vehicles
• *Less Special Value Packages
• *With Exterior Appearance - Level 2
• *Less Memory Package
• *With On-Board Diagnostic System
• *Less Special Language Label
• *Owner Hand Book Pack
• *With Power Front Windows
• *With Fixed Rear Vent Quarter Window
• *With Privacy Glass
• *With Mini Overhead Console
• *With Full Floor Console
• *Adjustable Accl/Brake Foot Pedals
• *With Carpet Floor Covering
• *Sunvisor - Dual Drv Illuminated
• *Sunvisor - Dual-Pass Illuminated
• *Less Running Boards
• *With Painted Front Grille
• *With Integrated Roof Rack
• *With Accent Wheel Lip Moulding
• *With Step Bar
• *With Electrochromic R/View Mirror
• *With Driver Electric/Heated Mirror
• *With Pass Convex Elec/Heated Mirror
• *With Black Exterior Mirror
• *Less Signal Mirror System
• *With RH Manual Lumbar Support
• *Less Temp Control Driver Seat
• *Less Temp Control Passengers Seat
• *Sec Row 60/40 (3 P)-Easy Entry
• *With 3rd Row Bench Seat
• *With Driver 6 Way Pwr.Seat Adjuster
• *With Heavy Duty Trailer Towing
• *With Front Towing Hook
• *Less Engine Oil Cooler
• *With Door Entry Remote Control Unit
• *With Remote Keyless Entry
• *Power Tilt/Slide Sun Roof
• *Front Bumper Painted In Bodycolour
• *Rr Bumper-Step Platinum G GLS Ford
• *With Front Licence Plate Bracket
• *Less Side Air Bag - Drivers Side
• *Less Side Air Bag - Passenger Side
• *With Steel Spare Wheel
• *With Standard Rear Shock Absorbers
• *17" X 7.5 10 Spoke Aluminium Wheel
• *P265/70R 17 A/T OWL
• *With Conventional Spare Tyre
• *With Super Engine Cooling System
• *Less Immersion Heater
• *With Standard Suspension
• *3.55
• *Rear Axle Limited Slip Differential
• *With Skid Plates
• *For Unleaded Fuel
• *With Tilt Steering Wheel
• *With Speed Control
• *With MPH/KMH Speedometer
• *Less Message Centre
• *Less Reverse Proximity Sensor
• *Standard Duty Battery
• *Elect Premium AM/FM Stereo/Cass/Clk
• *With CD Player Autochanger
• *With NAAO Radio Frequency
• *Less Upgraded Sound System
• *Less Family Entertainment System
• *Less Daytime Running Lamps
• *With Front Fog Lamps
• *With Conventional Headlamp Control
• *Oxford White
• *Less B&A Control Codes Issue 030388
• *(+)"USA"
• *(-)"CDN"
• *(-)"RA"
• *(-)"GU"
• *(-)"BRN"
• *(-)"RU"
Something wrong here.
Your vehicle shows as a 2007 - 2010 Ford Cmax , a totally different beast
D
doodlebugs-93
here is the information that you're interested in hope it helps.
Model Year 2007
Make Ford
Model Expedition
Trim Level XLT 4WD
Manufactured in UNITED STATES
Production Seq. Number A48209
Body Style SPORT UTILITY 4-DR
Engine Type 5.4L V8 SOHC 16V
Transmission-short 6A
Transmission-long 6-Speed Automatic
Driveline 4WD
Tank 28.00
Fuel Economy-city 14
Fuel Economy-highway 17
Anti-Brake System 4-Wheel ABS
Steering Type R&P
Front Brake Type Disc
Rear Brake Type Disc
Turning Diameter 40.80
Front Suspension Ind
Rear Suspension Ind
Front Spring Type Coil
Rear Spring Type Coil
Tires 265/70R17
Front Headroom 39.60
Rear Headroom 39.80
Front Legroom 41.20
Rear Legroom 39.10
Front Shoulder Room 63.20
Rear Shoulder Room 63.70
Front Hip Room 60.20
Rear Hip Room 59.90
Interior Trim Camel Cloth Interior | Camel Leather Interior | Charcoal Black Cloth Interior | Charcoal Black Leather Interior | Stone Cloth Interior | Stone Leather Interior
Exterior Color Black | Carbon Metallic | Dark Blue Pearl Metallic | Oxford White | Pueblo Gold Metallic | Red Fire Metallic | Silver Birch Metallic
Curb Weight-automatic 5805
Curb Weight-manual No data
Overall Length 205.80
Overall Width 78.70
Overall Height 76.70
Wheelbase 119.00
Ground Clearance 8.70
Track Front 66.90
Track Rear 67.00
Cargo Length 20.40
Width at Wheelwell 50.90
Width at Wall 54.50
Depth 35.50
Standard Seating 9
Optional Seating 7
Passenger Volume No data
Cargo Volume 18.60
Standard Towing 6000
Maximum Towing 9030
Standard Payload 1895
Maximum Payload 1895
Standard GVWR No data
Maximum GVWR 7300
Basic-duration 36
Basic-distance 36,000
Powertrain-duration 60
Powertrain-distance 60,000
Rust-duration 60
Rust-distance Unlimited
MSRP $32,145
Dealer Invoice $29,715
Destination Charge $900
Child Safety Door Locks Std.
Power Door Locks Std.
Vehicle Anti-Theft Std.
4WD/AWD Std.
ABS Brakes Std.
Automatic Load-Leveling Opt.
Electronic Brake Assistance Std.
Traction Control Std.
Vehicle Stability Control System Std.
Driver Airbag Std.
Front Side Airbag Std.
Passenger Airbag Std.
Anubis
The Gorge
You are correct it is a ex K9 unit, got it at an auction with zero info.
Got it at a good price and even came with the k9 cage which is what i really needed!
Pup loves it.
Have a few items to fix it up but it should be a good rig for us. Found the rear door panels on ebay with controls since they had removed everything.
You are correct, got it at an auction with zero info. Even came with the k9 cages!
Pup loves it.
Fizbain
Trooper, PA
Holy crow, I can not believe a thread has been active 5 years. Sorry for my first post to ask for something. Bought a used 07 EL Limited about 6 months ago and went to first RV show today. Go caught the bug. Now I am trying to determine what I can pull. Any chance you may be willing to dig into the database once again?
VIN 1FMFK20517LA91134
Anubis
The Gorge
I have another request if possible. I h ave a 95 Bronco that i am having issues starting since i never received any key FOBS with it and was wondering if it came with a factory anti theft option or not.
VIN #1FMEU15H6SLB23586
Thank you
yockmyer
Toledo
Would someone be kind enough to decode my VIN: 1FMFU18L83LC23727? I tried the FordEtis site with no luck. Thank you for your time and effort.
Jim
yockmyer
Toledo
Hey, no harm in asking I guess. Thanks anyway. :)
yockmyer
Toledo
Good afternoon...
I tried and still no result. However, My nephew took the VIN and looked it up at work. Thank you for your reply.
ktreem
Greenland, NH
haven’t seen much action on this thread lately but am in the market for an expedition max. Wondering if someone can give me the options installed on this vin?
1FMJK2AT7LEA31946
Thanks in advance!
tommyddsr
Portsmouth, Va
Just FYI on the FordEtis site. I received this email, here is an excerpt:
Dear FordEtis User,
In June 2021 Ford communicated to FordEtis users to advise them of the migration of FordEtis Online (https://www.etis.ford.com ) to the new Ford SERVICE Info site (https://www.fordserviceinfo.com ).
As migration is nearly complete, Ford will email a final confirmation of when the functionality will be available on the new Ford SERVICE Info Site.
The targeted date to decommission FordEtis Online is 6th December 2021. After this date FordEtis online will no longer be accessible and we advise that if you have any invoices or credit notes required for end of year financials.
You will need to download and back up invoices and credit notes before the target date.
Ford Service Info Site
Please register or login to the site to view all products and subscriptions that are available to purchase within in the Ford Service Info Site at www.fordserviceinfo.com
