Show your Lifted 3rd Gens
Aces
Murrieta, CA
Where is that, Utah? Arizona? Nevada? Or closer to home?
Closer to home, That’s burns canyon rd (2N02) from yucca valley up to big bear.
Looks amazing and obviously performs. Coil overs and UCAs up front judging by your signature. Any type of lift on the rear? Is there a ReadyLIFT or similar under there too (front or rear)?
The rears are just a bilstein 4600 with a 1” spacer.
Adieu
SoCal
Ooh, 100 miles from me
How much offroad capability required?
Aces
Murrieta, CA
When it’s dried out all you need is decent clearance. I only needed 4wd for some mud and ruts.
Richard Lucas
Ellerville 0K
2013 4X4 "NO AIR RIDE" Looking to replace shocks to much bounce and roll on the road 140k
Bilstein 24-1997717 and 24-197724, with Ready-Lift 69-2070 3" front, 2" rear....is what im looking at to purchase. This a good a setup for the money with good road manners live in the country on dirt roads! LOL
Amazon has it all in stock....$625 to my door!
Thanks,
Richard
Aces
Murrieta, CA
Thanks,
Richard
Looking forward to seeing it
Black
Kentucky
Thanks,
Richard
Bigger Tires?
Black
Kentucky
Bilstein 5100s at the top setting for the front
Bilstein 4600s with 2” Readylift spacer for the rear
275/70/18 Falken Wildpeak AT3Ws
No rubbing no trimming.
I gained 4” on the front from ground to highest point in the Wheel well prior to adding the larger tires (Bilstein claims 2” for the F150)
I will be dropping it 2 notches as 4” is too high and noticeable to much extension on big bumps.
RenegadeBad_Dog
South Carolina
I like it! Looks really good!
Sent from my SM-G973U using Tapatalk
16plati
VA
Too tall for front tires.
lvcjt702
Lost Wages
It's amazing how a little lift really makes these look like a real truck!
Sent from my SM-G935P using Tapatalk
RenegadeBad_Dog
South Carolina
So what is the biggest tire you can fit on the factory a 2016 with 18 inch rims without a lift.
mjp2
Howell, NJ
I’d like to see these big jumps you’re taking...
Bumps, not jumps. When you over-extend your suspension at ride height, the geometry goes wonky when driving over bumps and potholes.
Instead of the suspension doing its job absorbing the bumps and dropping into potholes, the effect of uneven road surfaces gets transferred to the truck itself and is felt by the occupants.
