st381183
Has anyone noticed how floppy the hood seems when driving at highway speeds? It even looked like the hood had popped but I checked it and it's closed properly.
65-85 mph. Of course it increases with speed but it flutters noticably, to the point where you second guess yourself whether or not the hood is latched. Seems like the hood needs stronger cross members or something.How fast are we talking? I know my Mustang moves a lot near 100 mph, but not at legal speed limit.
seems to be a common issue with light hoods
If you want to video something exciting wait for a breezy day with the wind coming from left to right on a single lane and wait for a truck to pass. You'll think the hood is going to crease.
My '15 Mustang hood used to move a lot until I adjusted the 2 rubber standoffs at the front corners. They keep the hood pressed tightly against the latch. No idea if the gen4 Exp is set up that way but mquick5 might benefit from this. The rubber standoffs look solid but they are actually spiral cut and thread in and out. Took me a few tries to get a perfect balance between the hood latching easily and no flutter. This is a fit and finish item they forgot about, at least on my 50yr Mustang.
Was it still under warranty? That's a factory defect. For long term effectiveness, you don't want to just use any plain old glue. That stuff is an expanding mastic made specifically for aluminum (among other materials).So I decided to pull the insulation off from under the bottom side of the hood and noticed that the glue that holds the outer hood shell and the inner structure together has come loose or separated.
