Ball mount
CHRIS JAMES
Along the Interstellar Divide
I don't have a trailer, but I want to pick up a ball mount to have if needed for anything. What amount of drop will work well on a 2019 expedition to get the ball at the right height for the average trailer?
Deadman
I went with a 6 inch drop solid aluminum receiver. Its close, but still a little hi
Plati
I didn't know there is an average trailer? I guess mathematically there must be an average … but don't you need to know the specific trailer to determine a drop is needed? I've always had no drop for my small boat, big boat, and snowmobile trailer.
duneslider
Utah
I have to be honest, I have 3 trailers and they are all at different heights. So, I bought an adjustable ball mount and change it depending on which trailer I am pulling. Then to throw in even more variability, my tow vehicles all have different hitch heights too. Since getting the adjustable ball mount, I now have 4 fixed mounts in the garage collecting dust...
I would say if you don't have a trailer and know exactly what you will need I would get an adjustable hitch. I use the Maxxhaul and for the $30bucks on amazon it has been just fine for me. There are nicer models out there but I don't tow that often so for the occasional trip to the home improvement store this works great.
C
CHRIS JAMES
Thanks for the feedback on the maxxhaul. I was considering that one.
NyackRob79
Nyack, NY
I'd probably get a ball mount AFTER acquiring a trailer, as different trailers have different hitch heights. The trailer should remain horizontally level when attached to the vehicle.
mquick5
Buckeye Country
How have we not covered ball size yet?
Sent from my SM-G935P using Tapatalk
That's the easy part. Big trailer, big ball. Generally anything with dual axle will take the 2 5/16" ball.
lvcjt702
Lost Wages
Oh, I get that. But if you wanted to have a set up around the garage what would be the "average" size ball?
duneslider
Utah
Anything under 5k-6K lbs will most likely be a 2" ball. I haven't used a 1 7/8" ball in 20 years, I haven't seen anything new with one in ages. You will only see 2 5/16" balls and big heavy trailers and in that case you will need a heavier duty setup.
I would have an adjustable 2" and you will probably never need anything else.
lvcjt702
Lost Wages
Next question.
Does anybody know the hitch height on the gen4?
