2007 Driver's door panel removal. What's the secret?
Gregg Eshelman
Idaho
I need to replace the driver's window switch cluster due to the driver's window going down but taking a lot of up clicks of the switch before it will go up. Just suddenly did that a couple days ago.
I looked up a video on Youtube of a guy removing the panel from the passenger door. He removed the six screws and pretty much just lifted the panel up and off, easy peasey.
Of course mine is acting like there's something on the upper front part not letting go. I got the upper hook at the back end loose but nothing else is giving up.
Dannyboy11222
Brooklyn
There's a clip located where the side view mirror are, you need to pop the clip off.. (The location the tweeter is) be gentle the plastic may be frale, pop that of before you try to pop the rest of the door panel off...
Sent from my LM-G710VM using Tapatalk
Steve Hartman
Lincoln, MT
Besides the clip you have a screw behind the door handle. Two more inside the armrest that are covered with a pop up plastic plate. Then there is one on the end of the door. It's a T-15 if I remember correctly. More screws on the bottom. Once they're all off just lift the panel straight up and it should come right off. How do I know this? Two windows regulators and a door latch! LOL!
