Tire pressures
16plati
VA
who here runs max tire pressures? Doesn’t matter if it’s lifted or stock, just curious as to how many people run the max pressures for whatever tires you are using
I run 40 psi on my Michelins, not sure what max pressure is though. It says 35 PSI on the door jamb as recommended.
Moderator
Max pressure is only for when you are running at or close to max tire capacity.
MuddySpokes
There & Here
On my tires, max is not stated on the sidewall.
When towing, I do start with the rears just under or at MAX COLD when cold.
Even when empty, there is no noticeable difference to taking them down to lower pressures. Am sure there is some scientific test out there that will show a difference of X inches or X feet stopping distance though. YMWV.
Also, am sure that there are plenty of ways that different people manage their tires. So, in this case, am not looking to claim which approach is best and am merely answering the original question ;)
TobyU
Are they mud tires?? Please show a pic of a DOT street tire that does not state max pressure, load range, and traction, tread wear, DOM etc on it.
TobyU
ALL tires that say 35 max get 35 or at least 34 if I'm in a hurry.
All 44 tires get 42-42.
All 50 tires get 42-45.
Any 55 tires get 44-45 or so.
All 60 get 55-60.
All 80 get at least 72. Since all my E range tires are on big vehicles and carry lots of weight.
I have had tire shops put a brand new E range on and put 35 in it.
That wouldn't even be safe on one of my 14,400 GVWR vehicle!!!
MuddySpokes
There & Here
Step into the world of LT's. It is common to see MAX COLD which is not MAX. ;)
LRNAD90
Since this is an enthusiasts community, and many people are running non stock tires, its probably helpful to also state the tire size, construction (P, P-Metric, LT) and load ratings. LT tires, for instance, will often run higher pressures than equivalent size in a P-Metric, to achieve the same load rating. Generally conversion tables can be found on the tire manufacturers websites..
But yes, according to the tire manufacturers anyway, maximum stated cold inflation pressures are for when the tire is expected to carry at or near its maximum stated load capacity, and can and should be decreased to match actual load carried for best results.
Here is an article pulled from Toyo's website as an example..
https://www.toyotires.com/media/2125/application_of_load_inflation_tables_20170203.pdf
Keep in mind this example is for a specific brand and model tire, but it gets the point across..
TobyU
Most tires, even LTS do not say maximum cold inflation. They say maximum load XXXX number of pounds at maximum pressure that is printed on the sidewall . Some may add cold for uniformity.
Even Turf & lawn mower tires have a maximum inflation credit on the sidewall. The first post was that there was no maximum pressure printed on the sidewall. I can't recall ever seeing a tire even on a two-wheel dolly but didn't have maximum inflation printed on the sidewalk.
No tire should ever be inflated past the maximum pressure stated on the sidewall.
It is irrelevant if you're going to haul a heavy load or not. If your load is over the maximum load rated on the sidewall of the tire at the maximum pressure then you need a heavier Rated Tire.
For uniformity we always check tire pressures when cold. This is not to say that a tire inflated to 80 lb cold will not be a few pounds over when it has been driving on the road for several miles.
But you never put 82 or 85 lb in that same Tire when it's cold because you're going to haul more weight. That is not appropriate.
lbv150
Northeast
Stock tire size I run 36psi. If you look up the tire manufacturer's specs, the max weight rating is at 35psi. 36-44psi only stiffens the side wall with no increase in weight capacity.
chuck s
If anyone has an Expedition with factory LT tires I'd be interested in seeing the rear GAWR as listed on the data plate.
My Expedition's Gross Axle Weight Rating (GAWR), the maximum permissible weight on the rear axle, is 4300 pounds. This can be achieved with the recommended cold tire pressure of 35psi in the rear tires. Normal inflation higher than that will just wear out the tread center more quickly (although radials minimize this).
The GAWR doesn't change if I put 40psi in the tires or put harsh riding LT tires on the truck. At 51psi (max cold pressure) the pair of rear tires will support 5512 pounds -- but the axle and suspension won't.
-- Chuck
TobyU
-- Chuck
Correct! It also doesn't really matter what the name plate for the manufacturer says. No tire should ever be loaded beyond the maximum load stated on the sidewall and that is at the PSI rated also stated on the sidewalk. You should never inflate a tire over the max pressure listed on the sidewall. If you do and you're trying to overcompensate for extra way you are already breaking safety rules by overloading the tires.
cmiles97
Tampa, FL
-- Chuck
2010ELExpy4x4
LT 285 70 17 load range E run them at 35psi for on road driving, even at that pressure feel the road more than the P tires it came with.
coolzzy
Idaho
Stock Goodyear wranglers, P275/65/18 I run at max pressure of 50 front and rear during camping season since I'm running at max tongue weight and any additional stiffness in the rear (side to side) is greatly appreciated. If these dang things ever wear out I'll go to a firmer sidewall tire but right now I'm at 47k miles and still at half tread depth....
lance0604
Manila
Ford Platinum EL 2016 model. Tires: 285/45R22 114H. Recommended pressure in the door sticker 38 PSI Cold. Philippines is a warm country with temperature ranging 30-35 C. I just follow the manufacturer's recommended pressure.
TobyU
We should eally pay more attention to the tire manufacturers ecommendations than the automobile manufacturers recommendation.
It's already been proven that a Vehicle Manufacturer can recommend a pressure that can easily result in dangerous conditions and accidents.
I don't think I've ever heard of a tire manufacturer messing up on their maximum inflated safety pressure. The worst that can happen even if you ran all tires at the absolute maximum pressure is you would have a firmer maybe bumpy ride, you could wear out the center a little faster than the complete width of the tread and you would be able to hold the maximum load with the vehicle without fear of overloading or overheating a tire. So not the worst things in the world.
Moderator
You should NEVER run at maximum pressure, unless you are running at maximum weight. When running at maximum pressure, without the weight, your contact area is decreased. Depending on how under maximum weight you are running it could be a significant difference. Less contact patch means less grip, and longer stopping distances.
Yes, Back in the 90’s Ford got in trouble for running Explorers and Rangers at less pressure than Firestone recommended for their OEM tires. They both paid for it, significantly! They will not make that mistake again.
I run around 38-40 based on what I have observed Tire wear wise and average load we run.
I have pushed it up more when towing, but don’t tow even close to Max regularly. Maybe 4-5K at most. Most of the time is a small metal yard trailer and around 2K loaded.
