Mine came in. Possible to install without a lift? Never crawled under mine.
-- Chuck
I placed the front of my vehicle on drive-on ramps when I installed the parts.
However, you could install the plate by crawling under the vehicle - but it would be tight. I would help if you had someone crawl partially under the opposite side and hold the metal plate on one end, and you hold the other end, as you start the bolts.
