Tailgate button sticking?
fishrising
CT
Anyone have issues with their tailgate button on the tailgate “sticking” and not “springing” back after you press it?
aggiegrad05
North Texas
Yes. Started happening about a month ago. Press it and nothing happens then it beeps a few times because it thinks I'm holding the button and trying to set the open height. I assume some grit or something got in there, just haven't had a chance to investigate.
F
fishrising
CT
Yeah, I need to poke around on it as well. Guess worse case bring it in to the dealer under warranty.
TKGracy
US
Ours had this issue from day 1. Ford is replacing the button next week.
Sent from my SM-G892A using Tapatalk
aggiegrad05
North Texas
I was just going to get my air compressor and blow it out...if that doesn't work I'll have the dealer fix it next time I'm in for an oil change.
AAOO
My liftgate is working properly. Didn't know tailgates were an option on the Expedition lol.
Traditional
Willmar Mn
Had the same issue. Then it stopped working altogether. Had the strut replaced and works great now.
nate6966
US
Will this be a recall item?
I would be shocked if it ever was.
Recalls tend to be done only when:
- problem has high enough rate of occurence
- problem has to be safety related or endanger people
- usually under recommendation of the NTSB
A sticky button for opening the cargo area falls under convenience and not safety.
I think the best hope would be a service bulletin that identifies a competent repair - and then the dealerships will still only provide the repair upon request and only if the vehicle is still under warranty.
julijn
los angeles
this started happening to mine too over the last 2 months...sometimes wont pop back for a long time then works for a long time. Its been working now but I wonder what's going on....
Jace
Utah
Mine just started doing it today... Luckily the every other method but the button works. Anyone run across any diy fixes yet?
Jay Dubs
CT
Same issue here, dealer is ordering a new one to replace it
TX-EXPMAX
you can set the opening height? Would love see if I can get mine to go up about another inch on its own. I can push it up manually and clear my head that way. Otherwise...bonk
aggiegrad05
North Texas
Yep. Manually (and gently) move the liftgate where you want it. Then hold the open/close button until you hear a beep. Now your liftgate will always return to that position upon open.
StealthyBulldog
Manitoba Canada
So, anyone?
I've found that I can press / move the little plastic piece surrounding the button and usually it will pop out. Thought about just trying to pop off the little 'surround' and see if it just needs a little shave of the opening or something.
NyackRob79
Nyack, NY
Same here. Dealer replaced the button, but blamed my Weathertech cargo liner for the problem.
Jace
Utah
So, anyone?
I've thought about doing the same, I just didn't want to probe too much and break it
That's interesting... I have a Husky mat back there. Did they say why they thought it was that?
aggiegrad05
North Texas
I don't have a cargo mat and also have this problem...don't eat the bullsh*t they're trying to feed you. If they really believed it was the cargo mat, they wouldn't have replaced the button.
