Tailgate button sticking?
fishrising
CT
Anyone have issues with their tailgate button on the tailgate “sticking” and not “springing” back after you press it?
aggiegrad05
North Texas
Yes. Started happening about a month ago. Press it and nothing happens then it beeps a few times because it thinks I'm holding the button and trying to set the open height. I assume some grit or something got in there, just haven't had a chance to investigate.
F
fishrising
CT
Yeah, I need to poke around on it as well. Guess worse case bring it in to the dealer under warranty.
TKGracy
US
Ours had this issue from day 1. Ford is replacing the button next week.
Sent from my SM-G892A using Tapatalk
aggiegrad05
North Texas
I was just going to get my air compressor and blow it out...if that doesn't work I'll have the dealer fix it next time I'm in for an oil change.
AAOO
My liftgate is working properly. Didn't know tailgates were an option on the Expedition lol.
Traditional
Willmar Mn
Had the same issue. Then it stopped working altogether. Had the strut replaced and works great now.
nate6966
US
Will this be a recall item?
I would be shocked if it ever was.
Recalls tend to be done only when:
- problem has high enough rate of occurence
- problem has to be safety related or endanger people
- usually under recommendation of the NTSB
A sticky button for opening the cargo area falls under convenience and not safety.
I think the best hope would be a service bulletin that identifies a competent repair - and then the dealerships will still only provide the repair upon request and only if the vehicle is still under warranty.
Dcleghorn01
