Push button start and key proximity
fishrising
CT
Is there a spot within the Expedition where you can place/hide your key such that it is far enough away from the steering column so that the push button start won’t work?
I’ve tried a few spots and the truck can still start.
I’d like to lock my keys in the truck (using the keypad to unlock) when hiking/biking/fishing and have the piece of mind that should someone get in they could not simply press the push button to start the truck and drive away.
aggiegrad05
North Texas
This is going to sound goofy but...take some foil along and wrap up the key before you leave the vehicle. A buddy of mine used to do this with his. Admittedly, his was an older vehicle and not an Expy, so tech may have advanced past this, but it did work for him.
Because no, I think they specifically designed it such that if the key is in the vehicle, it works. Which is actually quite convenient as I often leave mine in the cargo area when I’m loading up kids and stuff.
Wayne Decker
New York State
I do this too. I think the if someone broke into the vehicle the security system might disable the vehicle. I'm not sure, but I hope so.
F
fishrising
CT
Maybe I can roll the window down, lock the truck, reach in and open the door from the inside. This hopefully will set off the security system and then I can try hitting the start button and see what happens...
TheDoug
Mansfield, TX
If you lock the vehicle with the keypad, it should disable the key and start of vehicle until the proper code is entered to unlock.
Edit: just tested in my 2018...
1) leave key inside (anywhere you want)
2) lock car with keypad by hitting 7,8,9,0 at same time... basically stick you finger on the middle of all four of them
3) try and get in and you cant
4) unlock with your personal code
Wayne Decker
New York State
In Step 3: You mean another fob outside the vehicle won't unlock it?
TheDoug
Mansfield, TX
I did not try my other fob... i just meant that I could see my fob sitting on the seat and the vehicle would not open the door even though that fob was in proximity
And yes you can always use the ford app to unlock
lobsenza
You can put the key in a specially designed pouch that will block the key signal. You can then put it anywhere in the truck. Lock the vehicle with the door lock switch or keypad, Unlock it with your code.
rjdelp7
2000 XLT
NY
My cell phone can be locked with number code. They should make push button start vehicles, with a option to do it.
Wayne Decker
New York State
I tried the pouch they gave me for my EZPass and the key still works.
RhinoQuartz
USA/CAN
Ford (and Mercury, and Lincoln by extension) vehicles have had this feature for, literally, decades.
aggiegrad05
North Texas
I think he means a vehicle that can be started with the keypad. I agree it would be nice to be able to unlock my doors AND start the vehicle from the number pad.
oldfordguy
I am not endorsing a product here, but I got this from Amazon for mine. It is the perfect size for the Expo key fob and it works. Sorry for the font, just the way it copied.
Naviurway Small Keyfob Guard Mini Keyless Remote fob Holder RFID Key Fob NFC Garage Remote Protector Driver License Faraday Bag
benyl
Calgary
I left the key in my coat pocket that I put in the cargo area at the back. Key not detected. Wouldn’t start.
I leave my key in the expy all the time in the door pocket and lock it with the app. I don’t even know what my door code is.
If they want it, they take it. Key or not.
