Wind Noise
electrotanman
New Jersey
I have a 2018 Platinum that all of a sudden developed an annoying wind noise above 50 MPH. Driving me crazy !! Any one else experience this issue.
Thanks ! Love the info on this forum.
16plati
VA
Stupid question but are you sure every window and window vent is closed? Nothing stuck in there tracks?
nate6966
US
The driver side mirror on my 2019 has a slight whistle noise above 50 mph. I identified this by using the power fold feature at speed and the whist stops immediately when the mirror body moves.
I'll be mentioning it to the service department when I get my first service/ oil change here shortly.
Gumby
Beaumont, Alberta
My 2018 has the exact same issue. Power fold them and it goes away...annoying.
mmaylock
I've recently developed a whistling sound that only happens between 45 & 55 MPH. No noise below or above that speed range. Sounds like it's coming from the instrument cluster but who knows. I'm waiting for the dealer to get a new stock of loaner vehicles so i can drop it off...
I'll try folding in the mirrors to see if it has any effect.
16plati
VA
Noise cancelling speaker maybe?
Boose
2017 Platinum EL
NJ
my 17 had a wind noise when brand new. It sounded like the drivers window was just cracked... So annoying, it was right at my left ear. The dealer ended up replacing the window and door weather strip under warranty. The dealer has a process for isolating the noise... I made them find it and fix it. I know they're not Bentleys but I fully expect a 70K+ truck to function as designed.
Shawn Blankenship
Boose - I took my 19 into Ford, they said they hear nothing, looks as if I'm going to just pay them to replace the weatherstripping and/or whatever else seals the door - so ticked off. I told them the same thing, I paid 70k it should not have wind noise.
Boose
2017 Platinum EL
NJ
I hope that does it... that sucks.
Fozzy
Riverton
I thought my 19’ had a slight whistle by my left ear. It would come and go. I would lean forward and would swear it would get worse. It ended up being the air conditioning from the seats. Set in it just right and it would make a slight whistle on high. Pretty crazy. My 16’ F-150 you couldn’t even tell it had A/C seats. The Expy will freeze you out and blows enough you actually feel it and sometimes hear it.
Koz19MaxPlat
Long Island, NY
Hey guys. When I was driving my pre-owned '18 max home from the dealer 2 weeks ago I noticed the same noise. I thought that it was coming from the door/window seal until I put the window down and heard it continuing. Yesterday, I took the front of my hand and placed it in front of the driver side mirror, essentially blocking the flow of air from hitting the mirror directly. It stopped. This is absolutely the source of the noise.
Brought it in to the dealer today for a couple of service issuea, including the sunroof (tech told me "this is an old one, built in '18 and the seals need to be lubed and some screws tightened) and when I mentioned the mirror issue, the tech seemed to know about another TSB that he thought may apply to this truck. The fix involves taking apart the mirror assembly and packing a particular area near the wires with some type of foam, as there's an open channel that creates a wind-tunnel in those mirrors when you hit a certain speed. What's weird is that it doesn't happen below 45MPH or seemingly above 55mph- thinking that perhaps the airflow is too great or too slight for it to channel through the housing and that's why you aren't always hearing it. Curious to see if this is indeed the fix they will apply when I pick it up later. It helps so much when you have a tech who really knows their way around a particular vehicle.
scottdm
Western PA
Let us know what the TSB number is if you find out.
scottdm
Western PA
Will do. Having the same issue?
Yeah. Still not satisfied with the whistling sound around the drivers door. I've done all the typical remedies (tightened striker latch, adjusted door hinges, added tubing inside the bulb seals around the door). I have not considered the mirrors as a possible culprit, so I'll see if I can figure anything further out. Dealers aren't much help on stuff like this unless you can point to a part that needs to be replaced. They don't have time or interest to perform extensive troubleshooting from what I've found.
lv2drive
PA, USA
I too suffer from the wind noise, on the passenger side. sounds like the door isnt shut.
scottdm
Western PA
It's interesting that Ford can't figure these issues out on the Expedition. I have a 2020 F350 and it doesn't have any noticeable wind noise around the doors/mirrors.
Koz19MaxPlat
Long Island, NY
Yeah. Still not satisfied with the whistling sound around the drivers door. I've done all the typical remedies (tightened striker latch, adjusted door hinges, added tubing instead the bulb seals around the door). I have not considered the mirrors as a possible culprit, so I'll see if I can figure anything further out. Dealers aren't much help on stuff like this unless you can point to a part that needs to be replaced. They don't have time or interest to perform extensive troubleshooting from what I've found.
It's really maddening working with the dealer right now. I went on a ride along with a senior tech yesterday, he was driving, and I explained what he should look for. He heard it and he's the one who mentioned the fix with foam in the mirror. Another tech is working on the car today and the service advisor mentioned that they need to first replace some "rain/splash guard" on the window and see if that corrects the problem, to which I promptly told them that the noise is also present when you roll the window down and doesn't go away until you cup your hand over the front-face of the mirror. The response was "ok, but we still need to replace this part first." It just doesn't make any sense!!! That's not the source of the noise, what part don't they get?
