What's the rearmost point to tap some 40A power? Always-hot or delayed accessory or something...
Adieu
SoCal
Preferably NOT the dang defrosters, because powering it THAT way would be a farce that would qualify to be called a shamanic ritual
Goal: hotwire power 3rd row in an SSV
Method: bypass modules and crap (because I'm not even sure which parts I got and where), fit a momentary (hold to activate) "seat controls on" switch to a relay harness in lieu of the usual safeguards and to protect the battery from discharge if something is accidentally leaned against the switches
Issue: seats listed as normally fused @ 40A... the most accessible power donor, the nearby trunk power port, alas a mere 20A.
...or is this a non-issue with a circuit that's only ever hot when not one but two separate switches are simultaneously engaged, and only for a couple seconds? Thx
PS or is there a way to tap defrosters circuit from the back that would NOT involve having to activate defrosters to get power to the seats???
A
Adieu
SoCal
And yeah, as you might have guessed, I indeed AM indeed trying to avoid a scenario where I'm running 10 AWG all the way to the battery
A
Adieu
SoCal
Beats me, didn't have your fancy diagrams... I'll go shine a flashlight and maybe find out
TXFRDOwner
LOL .... That's where the circuit would get its power from anyway (if equipped)
A
Adieu
SoCal
Boxy thing above the ciggie lighter, also visible throught the vent-grating on the trim panel? Yup I got it
Is that all I need to hook up switches correctly? Or is that for the 40A workaround?
TXFRDOwner
Yes there's a 12V Constant and a 12v ACC in that box. Hopefully the slot for the 3rd row seat RELAY is pre-wired.
Did your Switch come with pigtails when you bought Trunk Trim panel ?
See the above diagrams for more details.
A
Adieu
SoCal
Ok, so violet is hot when...what, exactly?
Are the SJB and BJB components prewired for 3rd row power already? If not, what would I do to trick the thing?
Or just go with plan A and tap 40A power switched by a relay with a hold-to-engage button. Does that boxy thing have good old non-smart 40A power on one of the wires??
A
Adieu
SoCal
12V is a non-issue... it's the 12v 40A part that's troubling.
Looking inside, the switches have connectors terminating in cut wires, some idgit cut the harness
TXFRDOwner
It’s set up the way you described ... only works when you’re holding the switch (up or down)
Good ol’ plain relay circuit
TXFRDOwner
That’s great that the switches’ connectors are there. All you have to do is extend the wires and complete the circuit like the diagram shows.
Check the relay slot to see it’s pre-wired ... should see shiny terminals in the holes
TXFRDOwner
BJB = Battery Junction Box (engine compartment Fuse Box)
Feeds the aux relay box with 12V constant
SJB = Smart Junction Box ( Passenger Side Kick Panel Fuse Box)
Feeds the aux relay box with 12V Acc
A
Adieu
SoCal
Iirc, NOT REALLY
The SJB is supposed to cut power to it when in motion and when the liftgate is closed and in a bunch of other scenarios
Since I'm not sure which (if any) of those things are prewired for and I sure don't feel like paying to add em, I thought I'd just go with a more classical "hold button A to power switches B & C" safety measure.
But... I seem to need 40A power. Or do I? Will it blow the fuse if I try to run it off a splice to the ciggie socket? Or should I just refuse with 40A and that's that?
Heat/fire shouldn't be a concern with such short duration and infrequent use, and accidental engagement should be prevented by the additional "hold me to activate" button...
TXFRDOwner
if you're going that route ...
You'll find you're 12V constant in connector C410 pin 3, ...
splice in, add your 40A fuse inline. + your relay and replicate the wiring you see on the diagram minus the SJB.
Instead of a BJB & SJB feed. You're basically doing two BJB feeds
