It’s set up the way you described ... only works when you’re holding the switch (up or down)
Good ol’ plain relay circuit
Iirc, NOT REALLY
The SJB is supposed to cut power to it when in motion and when the liftgate is closed and in a bunch of other scenarios
Since I'm not sure which (if any) of those things are prewired for and I sure don't feel like paying to add em, I thought I'd just go with a more classical "hold button A to power switches B & C" safety measure.
But... I seem to need 40A power. Or do I? Will it blow the fuse if I try to run it off a splice to the ciggie socket? Or should I just refuse with 40A and that's that?
Heat/fire shouldn't be a concern with such short duration and infrequent use, and accidental engagement should be prevented by the additional "hold me to activate" button...
