Good Morning,
couldn’t locate Gen 3 Expedition thread regarding radar detector install mirror tap, may be just as easy using fuse box?
Has anyone been successful using the front upper console dome light or the power sun roof/side window for power and ground? Replacing the console with sun roof option, while replacing I was going to tap into power and ground connection for either function and install mirror mounted Uniden R3. Any issues using these power/ ground options switched? Having no luck so far finding the wiring diagram. Besides using my volt meter, any idea which wire is switched ign power and ground in map lighting or power sun roof/side window?
can always run down headliner to passenger fuse panel as 2nd option using an add a circuit to 31. Thought I would save time and wiring tapping into roof console area. Haven’t check mirror for white and black wires yet: It’s a 2012 Ford Expedition EL with rain sensing option.
appreciate any ideas and feedback to wire up the Uniden R3 near mirror and upper map console area.
Thank you,
Brian
Thank you,
Brian
