No lift, power running boards-will these fit?? 285/60 295/60
Jet225
louisiana
2015 4x4 with folding running boards, haven’t installed the lift yet but need tires bad. If I pull the trigger on either of these sizes will they fit without the lift on stock wheels?
285/60-r20
295/60-r20
thanks for any input
Moderator
You will Most definitely have issues in the front. The issue is width of those tires. You are going wider on both. I am running 275/65/20 on mine with the 3/2 lift and I rub at lock, and had to remove my WeatherTech Mud flaps. I have a 17 with the Electric boards. I was just barely, but it was with just a little turn, and was driving me nuts.
J
Jet225
louisiana
Would I have issues with the same size you have? Not doing any crazy wheeling, just need some grip and height for the hunting camp.
jonnyquid
were those 275/65s KO2s or another brand. it looks like the KO2s are shorter than others like Mickey Thompsons or Nittos, etc. About to pull the trigger on 4 tires, your help is important!
