Key Programming
dcsang
Hi to the forum once again!
I only have one key for my 2013 Expy and would like to know if FORScan would allow me to erase and reprogram two keys, my existing and one additional. Local locksmiths are charging varying amounts for programming and I would rather invest in a good OBDII scan tool for use with FORScan if that is an option.
I am new to FORScan, so if it is possible some guidance would be appreciated.
jeff kushner
North of Annapolis
I think this has been discussed several times with some really decent threads for you to read and learn from. I would search out the longer threads, and hopefully you can quick-study to get yourself up on the options. I watched a locksmith program a new fob for my '17 with a laptop and the new fob inserted into the key holder in the console(mine is button start). I am not aware of a obd reader which also programs but once you read the threads, you'll know who the experts are, reach out to them if you still need assistance.
good luck,
jeff
johnboneske
You can take your Key to Wallyworld and they will make a duplicate for $65, programmed like the one you already have.
Your post is a little vague.
Do you have metal key - which is used to start the vehicle? Or, do you have an intelligent key fob which is used to start the vehicle via a push-button start?
On my 2015 Expedition Limited 4x4, with an intelligent key push-button start system, I was able to program a OEM THIRD fob myself, using the two original fobs - according to directions on the Ford website. The fobs also have a hidden metal key, which is used to enter the LF door (but not start the vehicle). I realize you only have one fob.
There are numerous posts on this forum about programming key fobs.
D
dcsang
The 2013 is not push to start and this is my only key. The second image is a stock photo but identical. The 'SA' on the blade indicated an 80-bit key. My goal is to program a second key to the vehicle, and remove any others that might already be programmed.
Does anyone know if locksmiths typically use the programming or cloning method? I specifically want the second key programmed so I have the ability to add keys myself.
I've seen videos where FORScan is used to delete and reprogram keys but I don't feel fully informed enough to attempt it at this point.
johnboneske
View attachment 33059 View attachment 33060
wallyworld can do it for you!!!
D
dcsang
I read another post where someone got a duplicate key made at Walmart and there was no programming at the vehicle. That would indicate a cloned key, where the duplicate emulates the original. This would serve as a backup key but would not allow programming of additional keys using the 2-key method. My situation requires two unique keys to be programmed in the vehicle. I do appreciate your suggestion and it might be a cost-effective solution for others.
johnboneske
Your right, it is a duplicate Key... And no you can't get a third key programmed yourself, but it is cheaper to have them do a second and third key than it is to get a locksmith or Ford to do one for you.
Tocapet
Texas/Colorado
No, Wallyworld and Ace Hdw can only do clone keys. They work, but you can't use them to make a 3rd key.
I had a Dodge pickup once and only had one key. A guy came to the house with a laptop and made me another original key for $50 bucks.
rjdelp7
2000 XLT
NY
The programmer is very expensive and not worth buying, unless you are a locksmith. The original keys should of had a sticker on them, with a code. The dealer sometimes, puts them in the owner manual. Sadly, having only one key, will cost you $50-75 dollars. If you have both, you can do it for free. Sometimes aftermarket remote starters installers, zip tie the spare chip key in the steering column. It is a hack way to override the anti theft.
D
dcsang
The desire for a remote starter accelerated my need for an additional primary key. There is a programming sequence whereby the alarm/remote-start module is programmed using the 2-key method documented in the Ford manual, using one of the 8 available key placeholders. On the 2013 you can program 4 keyhead transmitters and 4 SecuriLock coded keys. My local locksmith charged $65 and I obtained a Ford 'refurbished' key on eBay for half the dealer cost. The seller also has a dedicated site. The key is an original STRATTEC, manufactured for Ford, 4-button transmitter fitted with a new key blade. It looks pretty authentic to me with exact manufacturer markings. The refitted blade is firmly attached and it took the locksmith all of 45 seconds to program.
D
dcsang
$70 “labor” & $139.95 for a new key at my local dealer.
The local Ford dealer charges $130 for the 4-button transmitter key blank and $150 to program. That's darn near $300 including tax.
bobmbx
And where did you hear that?
A month ago I bought a '16 Explorer Platinum. It came with only one Intelligent key. The dealer offered to program another for $450. I declined and in the same breath said "cuz I can do it myself for nearly nothing with FORSCAN"
They gave me a second, programmed key for free.
Gregg Eshelman
Idaho
I bought two keys off eBay for my 07, dirt cheap. I used FORscan with an inexpensive ELM327 clone USB OBD2/CAN device to program the second key then did the 2 key method to program the third key. A local hardware store cut them for free.
So there's one slot occupied by a lost key. To program a 4th I'd have to use FORscan to wipe ALL the key programming then use it to program at least two keys.
Why there's such a labor charge is from the second year of PATS on, there's an enforced wait time when programming each key. Getting set up and waiting through the wait to do the first key could take up to 20 minutes, around half of that just sitting there thumb twiddling waiting for the vehicle to say it's ready. Then you have that long again to wait to do the second key.
I used FORscan for one key because it was July and super hot outside and I didn't want to sit in the giant tan oven one second longer than I had to.
When you program a key from a 3rd party, TEST IT IMMEDIATELY AFTER PROGRAMMING. If it won't start the vehicle you don't want to wipe all the programming. You have to have two working keys programmed, even if you don't have both keys. If all the program slots are used and you only have one working key, then you have to do the reset and hope your bargain keys are compatible. Get stuck with only one key that works and a reset system, then you get to pay the $$$ to a dealer, or buy more keys to have cut, and hope they're compatible.
Expy00
Wife and I bought for her an '17 Expy EL previous rental that only had one key. I bought two more on Ebay after reading feedback. I knew I want to enable the trailer brake controller so I bought the
OHP ELMconfig Forscan OBD2 Adapter with MS-Can & HS-Can Switch for Ford DIY Diagnostics on Windows
Sold by: OHP Tools for 30 bucks. I was reluctant to erase all keys so I just added one using ForScan and free extended license. Later I found I could add OEM remote start so I bought two OEM remote start keys
KeylessOption Keyless Entry Remote Control Fob Uncut Blank Ignition Car Key Remote Start for CWTWB1U793 (Pack of 2)
Sold by: KeylessOption $44.95 on Amazon.
I did have to delete all keys programmed and start over since there were now 4 keys. I followed the instructions in this forum and ForScan site. It took several tries for the remote start to programming correctly but it did work. But getting the car to start with the key was never an issue. I have also added driving lights to the Expy and programmed a friend's '18 F150 to remove the Auto Stop/Start feature.
My local Locksmith cut the new keys for me.
Here is a link to PATS programming on the ForScan.org site
https://forscan.org/forum/viewtopic.php?f=6&t=839
