how are you all ؟
I hope you are all fine
Where can I find Throttel at Expedition 2015?
Is it possible to clean it?
The reason for this question is that I have had a problem over the past few days
When I try to accelerate I find the car as if it is without a gas pedal
Engine cycles are turbulent and decreasing to 500 rpm
And the gas pedal does not respond
I find the message "See owner's manual"
I used An OBD2 kit
The result was :
P2112-powertrain
Throttle Actuator Control System-stuck Closed
Thanks in advance for helping me
Best Regards
I used An OBD2 kit
The result was :
P2112-powertrain
Best Regards
