ForScan Tweaks - 2015+
Moderator
So the 15-17 Expedition BCM Configuration menu doesnt display this like the Fusion
Yes, it displays something similar. Can’t remember which are there and aren’t. Haven’t been in that area in a while. Been tweaking Sync 3 v3.4 lately.
None of those will get you the display on the Left MFD, because the BCM does not control that in most vehicles.
I have said this SO MANY times in so many threads on here, I feel like I need to save it to post it.
The BCM has the Data, but in all other Fords of this gen that I know of the DDM controls the left MFD, and the PDM controls the Right MFD. The 15-17 Expy has neither module. The ability to display might be there, but there is no reference to know the coding. The way these changes are typically discovered is using code from a vehicle that has the feature to give it to a vehicle that doesn’t. No reference vehicle in our case. Other than literally changing random bits, It is tough to know what needs to be changed. I have tried coding from MANY other Fords of similar years.
I moved on.
I use a Kiwi 3, and mobile FORSCAN or OBDLink to display pressures and other things, like IAT1 and IAT2. It works really well. I leave it attached all the time, and connect when I want to see info.
Again, the BCM has the Tire Data and way more, and the adapter and program allow you to access it.
star-art
Pacific Northwest
I think I might have a theory as to why we can't get Tire Pressure to work.
Our 2015-17 trucks are basically the same as a 2014 F150, right? I read that the 2014 F150 uses different TPMS sensors that are not compatible with later F150 models. Tire pressure display didn't become available on the F150 until 2015. And, as it turns out, our 2015-17 Expeditions use the same old-style TPMS sensors as the 2014 F150!
9L3T-1A180-BB, CM5T1A180AA, 9L3Z1A189A, ZZDA37140
Current part# 9L3Z-1A189-A
FITS:
FORD C-MAX 2013-2018
FORD E-150 2010-2014
FORD E-250 2010-2014
FORD E-350 2010-2018
FORD E-450 2010-2017
FORD EDGE 2011-2015
FORD ESCAPE 2009-2018
FORD EXPEDITION 2011-2017
FORD EXPLORER 2011-2015
FORD F-150 2009-2014
FORD F-250 SUPER DUTY 2010-2016
FORD F-350 SUPER DUTY 2010-2016
FORD F-450 SUPER DUTY 2010-2016
FORD F-550 SUPER DUTY 2010-2016
FORD FIESTA 2011-2018
FORD FLEX 2012-2018
FORD FOCUS 2012-2018
FORD FUSION 2010-2016
FORD MUSTANG 2010-2013
FORD POLICE INTERCEPTOR SEDAN 2013-2018
FORD SPECIAL SERVICE POLICE SEDAN 2014-2018
FORD TAURUS 2011-2018
FORD TRANSIT 150 2015-2018
FORD TRANSIT 250 2015-2018
FORD TRANSIT 350 2015-2018
FORD TRANSIT CONNECT 2010-2018
LINCOLN MKC 2015-2018
LINCOLN MKS 2011-2016
LINCOLN MKT 2011-2018
LINCOLN MKX 2011-2015
LINCOLN MKZ 2010-2016
LINCOLN NAVIGATOR 2011-2017
MERCURY MARINER 2009-2011
MERCURY MILAN 2010-2011
We used to have both a 2015 and a 2016 Explorer. As I recall, the 2016 had the tire pressure readout in the cluster but the 2015 did not. It seems Ford changed the tire pressure sensors for 2016 Explorer models.
This might explain why we have a TPMS warning light but can't get actual tire pressure readouts in the IPC. Even if the BCM has tire pressure data to drive the TPMS warning in the cluster, the data might be in a different format than what would be needed for a tire pressure display.
So, is there a workaround? Not likely. I don't know much about the TPMS in other Ford vehicles, but our 2015-17 trucks have a Tire Pressure Monitor (TPM) Module that sends information to the BCM. This TPM is apparently programmed to receive data from the older style sensors. The TPM module also has an integrated antenna for the Remote Keyless Entry system (for vehicles with Intelligent Access, otherwise the RKE antenna is in the BCM). It communicates with the Remote Function Actuator (RFA) Module over a dedicated "K" line.
Hope that helps?! :)
star-art
Pacific Northwest
How much info do we have on settings in the BCM? Since both older and newer vehicles send TPMS data to the BCM, I'm wondering if there is any sort of setting or control for the format of TPMS data. Vehicles with tire pressure readout may receive their sensor data from an RT (Radio Transceiver) Module instead of a TPM module. If the BCM can read this newer style data, it might be possible to enable the display in the IPC. . .
Moderator
Nope. Has nothing to do with the TPMS sensors. If the BCM can see the Data. The different sensors have to do with frequency, battery life, and reset procedures.
Every vehicle with the dual MFD’s that has DDM and a PDM can display tire pressures on the left, and climate and temps on the right. Something else the Expy cannot do. That includes the Fusion/Edge platform that I have spent A LOT of time programming on.
Another thing that blows your theory out of the water. Your list above includes the 2015 Edge. It can display tire pressures in the left MFD, and actually does from the factory. What is different? It has a PDM and DDM.
There might be code, but again NO reference.
Dead horse people, dead horse. With out a ford Engineer or a reference vehicle. The reference vehicle has to have dual MFD’s and no DDM or PDM and display Tire Pressures.
I personally don’t think the code exists. The 15-17 was a stop gap/hybrid of new and old. Ford merged some newer tech and the EB motor with an old platform until the new model was ready, otherwise known as the 4th Gen.
Plug a BT module in and use FORSCAN mobile, OBDLink, Torque, or whatever your app of choice is. Works great. Plus I get to see WAY more.
Good luck spinning your wheels, pun intended!
TXFRDOwner
LokiWolf .... I'm gonna apologize in advance. I know you are frustrated with us stumping this dead horse deeper in ground, But out of curiosity are these hex bit changes some of the ones you tried ?
Moderator
Pretty sure. Looks like F150 coding. I was not the only one who tried to get it to work....
You are welcome to try it. If it works, awesome!
star-art
Pacific Northwest
You obviously know a lot more about this than I do. I'm not trying to argue, just offer whatever I can in hopes it might help.
I also read there are two types of tire pressure sensors -- "high" type and "low" type. The 2015 f150 BCM has additional lines of code for TPMS settings that include flags for sensor type (see attached). These lines of code don't appear in my BCM so I'm guessing the older 2014 f150 BCM wasn't capable of handling more than one type of sensor, but the newer ones appear capable of handling both types.
The newer sensors also come with many new programming lines in the BCM related to TPMS features like programming the sensors (i.e. "learn") and keeping track of where each tire is on the vehicle. At least that's what I am reading from the attached.
TXFRDOwner
Got this off of DanMC85's Forscan Fusion spreadsheet.
I'm on the road for work at the moment but I'll give it a try the first chance i get.
star-art
Pacific Northwest
My old 2009 FSM has a section on module communication that lists all the modules, what bus they are on, and even a table of the different messages being sent back and forth over the bus with origination and destination modules. Is something like that available for any of the vehicles you mentioned that have a DDM and PDM transmitting data to the IPC? Just curious! Thanks! :)
Moderator
Does it exist? Probably. Do I have it? No. Do I think it would matter? No.
Moderator
Most likely I tried it. Fusion and Edge use the same programming. My other vehicle is a 2016 Edge. Only vehicle I have spent more time inside the modules than the Expy...
The pictures at the beginning of the thread were taken of my Edge. At the time I assumed I could do all the same things to the Expy. I was so wrong.
I hope it works! Maybe you stumble across the right combo. I and 2 others(that I know of) tried many combos trying to get Tire Pressure, Boost, and Climate to show up on the MFD’s like is possible on other Fords of similar generation.
I really do hope it works....yell back.
star-art
Pacific Northwest
I'd like to dig into some factory service info for F150. But, thanks to TXFRDOwner, I was able to study the Fusion a bit. The DDM and PDM do nothing but control power windows and mirrors. Not clear at this point if they communicate anything to the IPC. These modules were added as a money-saving way of reducing the amount of wiring needed for a car. Rather than run wires from a memory module across to the passenger door, the modules just talk to each other and control those items locally. The module also allows for features like remotely controlling the windows.
The Fusion DDM has no programmable parameters, but Programmable Module Installation is "available." Don't know if it's required or not. It might be possible to get it running in another vehicle if only as a way to add the "auto power fold" feature for the mirrors. You could connect it to the power-fold motors on each mirror and the CAN bus and just use it for that.
While I don't claim to be an expert by any means, I can see that the BCM and IPC don't communicate directly with each other (on the Fusion). All messages are translated through a Gateway Module. At this point, I strongly suspect the newer vehicles with features we are missing (auto power-fold, tire pressure display, active parking lines, etc.) have updated and/or more advanced BCMs. I don't know if these are physically different, but their programming certainly is. They have totally different firmware that includes expanded parameters -- both for setting options and for communicating on the network.
Moderator
And where are you getting this info, from actually making changes in the module or theory?
star-art
Pacific Northwest
Just from reading the factory service manual and studying the vehicle network topology, along with some of the module programmable parameters in the F150 spreadsheet. The Fusion service manual describes exactly what the DDM and PDM modules do. My older 2009 Expy manual lists a rather complete Module Communication Chart that lists the different messages the modules send to each other and on what bus. If we can get that for Fusion and F150, it might make it easier to see what sorts of data the modules are sending to each other and, therefore, what parameters they may require in order to work.
I spent many months studying all this for my older Expedition in hopes of getting heated/cooled/memory seats to work in a truck that didn't have them. I'm not sure anyone ever did that as a successful swap and I can certainly understand why. While I was able to figure out what data the DSM and DCSM modules needed in order to operate the seats, safely getting them that info without risking "injecting" unwanted traffic on the bus would have required extracting specific messages from the MS-CAN bus and passing those through a custom built gateway interface. That was (and still is) beyond my capability.
BTW, on Fusion, the TPMS system also requires communicating with the APIM for both tire pressure status and tire pressure warning. Has anyone explored those settings?
Moderator
So it appears I misspoke earlier.
I got on my laptop I use for tuning and programming and looked at my notes. Sorry, it has been a awhile since I have made tweaks other than APIM related.
The theory is that the lack of a DDM and PDM means that the BCM/IPC has to do more heavy lifting. So the “space” in the BCM is different than all other BCM in similar other Ford vehicles of the same generation. So it isn’t that the DDM controls the MFD’s but that the code is different between vehicles with and without.
I stand by the statement I said earlier. Find a Ford vehicle with the dual MFD setup that does not have DDM or PDM and has TPMS displayed. Then we will have a code reference to compare.
The APIM is involved in TPMS because that is how it does the Audio notifications.
Moderator
I did try it. The problem is the code isn’t the same that is supposed to be there. That was my note.
Specifically - “Hex not as expected”. That is what I typed.
star-art
Pacific Northwest
The theory is that the lack of a DDM and PDM means that the BCM/IPC has to do more heavy lifting. So the “space” in the BCM is different than all other BCM in similar other Ford vehicles of the same generation ... Find a Ford vehicle with the dual MFD setup that does not have DDM or PDM and has TPMS displayed. Then we will have a code reference to compare.
Makes sense! Our BCM likely has totally different firmware so certain functionality simply isn't there. I'd bet it's a "holdover" from 2014 with modifications only in code, making it a bit of an "odd duck." The reason "why" is likely just trying to save money.
All this will start to come into sharper focus if we can get more info on the CAN messages being shared between the various modules...
Moderator
You are welcome to try to figure that out, but it won’t bring us any closer to getting it to display. Have to have a reference code. Something to compare. We don’t have that, so done. The CAN messages won’t get us the code.
Again, Dead horse.
Sorry, been working on this so long, I have just moved on. Found a solution(BT ODBII adapter and my Phone), which is mounted in my ProClip Mount to the right of my Sync Display. I see everything I need to, plus more!
Lou Hamilton
In order to make changes, do you need the full Windows version or can I make the changes using the iOS app on my iPad?
I plan on buying the ODBLink MX+ adapter.
Thanks!
