Go to ford.com and search sync update. You put in your info to login or register. There will be instructions on how to upgrade the firmware. You download to the computer, unzip the file, put everything on a thumb drive and put the thumb drive in one of the front usb slots, the system does the rest. Important that the rig stays engine running until the update is completed. Disable “auto engine off”. Takes about 40 minutes. Cycle vehicle completely off, restart and firmware is upgraded. The Ford site has pretty good instructions from how to download, set up the thumb drive, and what to expect when in the truck. Maps update is basically the same but the files take about 2 hours to download due to large size and about an hour with the motor running to transfer into the nav system from the thumb drive. I erased all other data from the thumb drive and had only the files ford stated on the thumb drive. Make sure you format the thumb drive to exFAT32, not “FAT32”.
BTW, after doing the upgrade, you can go back to the owner.ford.com website for the SYNC update and upload a file after the update. This is supposed to let the "mothership" know what version you are on.
After upgrading to v3.4 and trying to upload the xml file showing what version I was on, I get an error that the file is not valid. It worked fine when I did my initial v3.0 upgrade to the most recent build. But it is not working for the v3.0 to v3.4 upgrade.
Just an FYI. If anyone has got this to work, please let me know. I have tried different browsers and computers without success.
Got it to work!!! Now I need to get the Forscan program and hub. I want the Lincoln screen. Thanks.
Meh, let me know when you get a fancy illuminated grill ornament lolAwesome!
My son had a Windows laptop that he just gave me. He uses his desktop mostly for school programming. He thought he would use this hybrid laptop/tablet but never liked it.
Updating Windows 10 and then will load ForScan. ODBII module was just ordered too.
Happy days are coming with the Lincoln Sync theme. Now @Artie can't be the only guy on here with a fancy screen. LOL!!!
OUCH!!!
https://www.americantrucks.com/putco-f-150-luminix-led-front-emblem-92602.html?utm_content=AT Exterior - Emblem|Putco&T5_Var4=T542788&utm_campaign=ATF+F150+Vehicle+Medium&dialogtech=ppc&utm_source=google-pla&utm_medium=shopping&T5_Var2=shopping&T5_Var3=orange&intl=0&gclid=EAIaIQobChMIj8S0scvv5gIVEfDACh0hDQrJEAQYBCABEgJ5cPD_BwE&gclsrc=aw.ds
Here you go. Saved you $20K
That’s funny!https://www.americantrucks.com/putco-f-150-luminix-led-front-emblem-92602.html?utm_content=AT Exterior - Emblem|Putco&T5_Var4=T542788&utm_campaign=ATF+F150+Vehicle+Medium&dialogtech=ppc&utm_source=google-pla&utm_medium=shopping&T5_Var2=shopping&T5_Var3=orange&intl=0&gclid=EAIaIQobChMIj8S0scvv5gIVEfDACh0hDQrJEAQYBCABEgJ5cPD_BwE&gclsrc=aw.ds
This thread was painful to read!
Looks like I need to pay attention to the Gen4 area more so I can cut down on the MIS information a bit about Sync 3.
Yes, if you are running 3.3 or above you can use the USB Hub with the USB C.
3.4 can be done on any Sync 3 system without doing the Firmware or having a new APIM using the Format Tool.
This is the process you should be following and files you should be downloading.
https://cyanlabs.net/tutorials/update-ford-sync-3-2-2-3-0-to-version-3-4-all-years-3-4-19200/
I am up to 9 systems now. 2(My 16 Edge, and My 17 Expy) were done prepping all the files manually several Months ago. The other 7 using the AIO’s from Cyan Labs. I highly suggest going to 3.4 19274 after going to 3.4. It is FAR less buggy.
Just to be clear, there is a risk of bricking your APIM, and this is AT YOUR OWN RISK.
Should we start a new thread so this is easier to find?
You should pin it in both forums. I have zero reason to look at 3rd Gen posts.
Thanks for the links! I’m a chicken, a cheap chicken and I think I’ll stick to Ford’s official updates for now. Especially as I really don’t know the ramifications and nuts and bolts of what I’m doing and potentially bricking an expensive and critical module and system is beyond my comfortable risk level.Never said you should. I really have no reason to look at Gen4, but there are MANY common issues between the 2, especially us 15-17 owners. 16-17’s have Sync 3. 15-17 have EB 3.5’s, albeit 1st Gen.
Yet I came across this thread because another user asked me to take a look, because I know Sync and FORSCAN pretty well.
Just wanted to clear some things up. Just wish I’d have seen it sooner, could have made it easier sooner.
Cheers!
