Poor Gas Mileage
Brooklyn, New York
I purchased a 13 Limited about a month ago with 97k on the clock. In the few short weeks that I've owned Betty she's been draining the wallet at the pump. She's worse than an alcoholic at a party serving free liquor. Engine is running smooth no hesitations. I've reset to the fuel economy settings to try and get a feel of gas mileage, which is reading anywhere from 8 to 9 mpg in city(Mostly) some stop and go traffic. I have had two other Expeditions before and I know they suck some gas, but not like this. Burning mostly premium gas. what can I do, where to start to combat the evil witch's drinking problem.
chuck s
Here in Virginia Premium gasoline is 60¢ more a gallon and is, of course, a waste of money for an Expedition with the 5.4 V8 which runs just fine on 87 octane.
Got Overdrive turned off or tow-haul turned on for some reason? That won't help. Check pages 215 (or thereabouts) in the owners manual.
-- Chuck
JasonH
Houston, TX
Try running a 30 to 50 miles highway loop and see what mpg you get. Check tire inflation and air filter first. If you have a Bluetooth OBD scanner you can also use an app like torque to view stats like stochiometric mix, EGT, etc in real time.
TobyU
That certainly doesn't sound right unless you were awful heavy on the gas pedal and doing real hard takeoffs.
John Kohler
St. Louis, Missouri
There's no benefit to using premium gas in a naturally aspirated engine without high compression. Shell claims their premium has enough additives to "clean" the engine, so tank of that occasionally might be beneficial (like dropping a bottle of fuel system cleaner in).
Blksmk
Canada/USA
Stop looking at the on board computer display. Then start driving it like a heavy tank. Nice and slow, my 07 get 22 to 24mpg highway, city I never checked. As I rarely drive in any cities or towns
Powerplay
America
I’m having same poor fuel economy with my 12 Expy EL with 106k. Noticed fuel economy start dropping from 19-20 to 12 mpg with a mix of city and hwy. Truck runs and shifts great. Using 87 octane, empty cargo with fresh synthetic. Going strictly by on board readings, drove 22 miles on hwy and 10 on city. MPG still at 12. Acceleration was easy on the throttle. Even using winter blend fuel the mpg didn’t make a difference, would think the economy would decrease.
Any ideas how to start checking condition? Would cold air intake help? I’ve been advised by a few Expy owners cold air intake didn’t increase their mpg.
Thanks in advance for any ideas.
Plati
Of course I'm not saying you weren't getting 19-20 MPG "before", since I'm not you and not there BUT I find it very difficult to believe any 2012 Expy EL would get 19-20 MPG under any conditions other than a tailwind or downhill. I get a bit less than 18MPG (best) on my 2014 when I'm cruising level ground on the interstate going 65. 5.4L
Hope its OK to say this. Not being a ******.
Blksmk
Canada/USA
Its colder so youre running the engine longer burning more fuel. I'm getting 21 to 22.5 mpg at -30c on the highway.
Hoffy90
Oregon
I picked up a 2013 EL wtih 136k a few weeks ago and getting around 12.8 mostly city driving. So far just a K&N drop in air filter. Maybe try air filter, spark plugs and MAF sensor cleaner?
Sent from my Pixel 3 XL using Tapatalk
Franklin Jones
Nebraska
How are the plugs? Still original? Probably worn out and need replaced.
I had the same experience on my 14 with 105k, 8-9mpg, and when I dropped new plugs in it it jumped to 13 in city.
O2 sensors are next on my list.
ManUpOrShutUp
This is straight highway driving in my '11 EL and only holds up as long as I'm cruising at moderate speeds, but it is doable.
sjwelds
Kansas
Question for the collective:
Can an O2 sensor not throw any codes, and yet still negatively impact fuel economy?
bobmbx
Oh yeah. Thats generally how it happens, btw. The sensor is providing ********, but still "in range" data, so the PCM thinks the data is correct and starts making fuel trim changes.
Plati
There was a guy posting a while back about that. His claim was that O2 sensors are an item that should be periodically replaced, even with no codes. Sort of like replacing plugs. I think I saw another post about how you can get the data the O2 sensors are providing and make a decision about how "healthy" they are. The guy claimed it can be a big hit to MPG. Pretty expensive to replace I think so it seemed like money chasing money. I've been curious about that since I saw it.
Franklin Jones
Nebraska
The upstream O2 sensors are how the PCM determines the quality of the burn and how much fuel to inject.
The downstream only monitor catalytic converters efficiency.
So if you want to replace them for MPG purposes, you only need to replace the upstream ones.
Aspen03
Indianapolis
I've experienced this a couple of times on previous vehicles. Reading live data is about the only way to see if they are "tired" or not. Knowing what the mv ranges correspond to afr wise is necessary if you want to really determine how they are performing.
They're fairly inexpensive to replace...$30ea I want to say when I ordered some Denso's for my in laws expy a while back. Considering the impact they can have on fuel economy it wouldnt take long to recoup if it is the issue. 100k miles is more than enough to warrant replacement if they are original even as preventative maintenance.
TobyU
I would say that mostly that was just a claim.
People have been lying about fuel mileage for decades.
The auto parts stores and manufactures like Bosch have been saying you should replace your oxygen sensors every so many thousand miles for fuel mileage also but they have a vested interest in selling oxygen sensors.
I'm sure they can get lazy but I would hook up a live monitoring scan tool and watch what they're doing.
If I were going to swap some out to test I would make sure I bought some very economical ones on eBay.
Blksmk
Canada/USA
368 mile highway run at 70 mph with 25 to 35 mph wind I got hand calculated 14.88 mpg
tommyddsr
Portsmouth, Va
So I just bought a 2009 EL a few weeks ago. Previous owner did not clear the onboard computer and it read 9.2 MPG average. I figured he must have towed a trailer or something. Long story short, best I could do was 11 - 12 MPG, city/hwy. Put new plugs in it last week even though it was running smooth. Now getting 20.4 on the HWY (60 MPH on Cruise Control for approximately 100 miles) and 14.9 city. And for the non-believers, here is the screenshot to prove it. Loving life in the new Expy now.
qaSVPjs3_XAsR8AsaCnQ3SBBtz_6cS-_9_Ww2fSHLhYTF5vKiqCy-DlivLNdYTPkpbophGJaE1qbrb0LDS6EaTDCH5J4pSgrwyRDZNl1Des0Lqotvto507WDWo7ebi4E-BHkzmOHWNBTbBtYXSqcg3irO8Bu93ypQR_zI3QPUZJElpsWqx_1hyFMVUy9F3b72Z9z8kuXSwzY1T9hk_O0nEJ6qTLHMxiqNjwfJLiXh1dhxFNxrppYMG3TDdEwTAHIlbZAzpND5FJss0OH7wl__3gPUIXhuKiMBLlJMvj4vKrplIH7VNFni-AGK2lJ8pp70pUwTh0oDcwJmaV4nBZa9a_KQ0vr_PhVlqPUQh8I4SANr5fAlG6ahld1VOS8rIAzJghDCMdDe8k55dT5ns0O_jB41W1aWujnR9CwrMuxMPzixarstszeHJQttUGAmbN2hSHPjvsjYouCPusg53OCqzkor6pxvbH1LVTTctJD9OVshSQpVmtWQkhVfqpf-mX5iG5UX2Uks81-K0OnwTMXXa9gt7gc46eFgzGFb2uyphBRaaI6NMkysy6CKgbEJpH11soQ9gzncixb9u4bI8B0A9eQ__1AibSvgvHnHFEJCVac7yzyBYdRBQ0LelxSa49wsjoEZxRL2pidRrSmoHximY1Xe1SbRo37YgqIHVFHcQnAxNw656cy4jE=w937-h703-no
