My Little Build - 2005 Ford Expedition Eddie Bauer, Heavy Towing Package 4x4
MasterX
Arizona
Ive built up numerous vehicles, motors, etc(mostly for my Mustangs), but this is the first time doing a truck so i figured i would throw down a post now that a lot of it is done.
2005 Ford Expedition Eddie Bauer, Heavy Towing Package, 4x4, power everything...
So I bought the truck with the intent to set it up nice for a planned family vacation as hauling 5 people plus supplies and baggage across the country was not going to happen in the vehicles we had which are:
04 Hyundai Santa Fe, a tuna can of an SUV
07 Mustang GT, (My Modded out Street Car)
13 Hyundai Elantra, another tuna can
I Decided i wanted an 05+ Expedition because i know ford pretty well, especially the 3V V8 engines which is the same as my mustang just a 5.4 vs a 4.6, meaning lots of experience and even spare parts carry over. Was going out for an 07+ but decided 05 and 06 were acceptable too just without the nicer tranny.
Scored my 05 on Offerup, i was on there live when it was posted and went right then and there to see it only about 6 miles away, and after digging all through it and test driving it i dropped 2500 bucks on it cash. I got it cheap because the previous owner admitted to trying to tow some 30 foot flatbed loaded to the piss with shit and even another vehicle when they moved here, and they blew out 3rd and 4th gear allegedly while going up a hill with way to much load, he also admitted they forgot to turn off OD. So they popped the tranny. And the amazing folks who i now love at AAMCO told them it would cost $4000 to pull, rebuild, and reinstall the transmission, (which is absolute rape and robbery btw), so the owner didnt want to spend the cash to fix it, the transmission was its only issue, even the DVD player still works...
So i brought it home, and on the way home found out they werent so smart, 3rd gear was fine, but the truck was jumping so fast from 3rd to OD and going free spin that 3rd seemed like it was also dead, popped off the OD button and 3rd gear is perfectly fine all the way home, and no more free spin or slip at all, so seems they just blew out overdrive.
So my dad is a diesel engineer and knows a guy for damn near anything, so i got his transmission guys number and dropped off the truck, which kinda sucked as i had to drive about 40 miles without OD/4th gear, and very little freeway so i wasn't running high RPM for too long. They threw in a fully rebuilt 4R75 Transmission off the shelf, and even noticed a broken ball joint and asked, so i had them fix that too, all considered including labor and fluids i was only out 1300 bucks.
Now that its solid, i began the modding and ill keep it short, this is what i did.
Ford Roof Rack Cross Bars (they were missing)
Extended Full Length Roof Rack from Amazon
5 x 2.5" LED Pods (Mounted forward on the roof rack as offroad lights)
2 x 8" LED Bars (Mounted rear on the roof rack as offroad/backup lights)
2 x 7" Sealed Beam Buckets in the Grille with LED 90w headlight bulbs
3 x 3Amp Dual USB Charger inserts (front & middle row, and back cargo area)
1 x 3Amp Dual USB Power port replacement socket (cut a hole, and installed for 3rd row)
Android 8, 7" Head Unit (Quad Core, 4GB RAM)
USB Surface mount extension (on dash, exposes Head unit rear USBs to dash use, flash drives, etc)
Pilot Auto Wireless Remote Relay Controller (Controls all the additional lights i added)
Frontier Truck 200-10-3004 Heavy Duty Steel Grille Guard/Push Bumper
Trail Ridge Tow Mirrors (Power, Turn Signal, Puddle, Memory, Telescoping, etc)
The push bumper is fantastic, Very thick steel compared to others ive seen, and mounts to 6 points on the frame, We stood and hopped on it and it didnt move at all. We got it here:
https://bumpersuperstore.com/i-1145...4-grille-guard-ford-expedition-2003-2006.html
I had Audio Express run a 4 conductor cable up the front pillar to the roof to provide power and connectivity for the offroad lights, and mounted the controller on the roof rack up high so i can control the lights from extreme distances away from the truck if needed, it goes through the roof with a waterproof trailer plug so i can easily unplug and remove the rack if needed. It almost looks factory esque, they may not always do things properly on their own, but audio express seem to be awesome at following directions if you tell them exactly what you want, with a drawn up plan.
The rear diff had a small leak i discovered, so i had a shop ive used for my mustang diff swaps fully rebuilt the 9.75" pumpkin case of the expeditions IRS rear, bearings, seals, the works. Front diff checked out fine. This was when I learned it was a heavy towing edition, the ordered the parts for a standard and nothing was right, hehe... 4x4 and heavy towing package, SCORE!!!!!
We tore through California on I-8 even during a big wind and rain storm at 85-90 from arizona to san diego and onto base at NAS North Island, one of our required stops, on a single tank with some to spare. Truck did perfectly and the Vaca went without a hitch.
MasterX
MasterX
Arizona
More Pics, the Blue USB 3.0 ports next to the 4x4 selector switch are the inputs to the Head unit so i can connect flash drives, a wireless keyboard, charge stuff, pretty much any usb accessory, the dash unit also has 4G as i popped in a Google Fi sim card, so no wifi or tether needed for google maps navigation right on the dash, and the head unit puts off its own vehicle wifi signal for occupants.
The two rear light bars are angled slightly downward from above for either backing up, or work lights behind the truck, offroad, etc...
Donald Bell
Dayton, OH
Looks good bud just switch out those ugly wheels and you're gold. I put some 2015 F-150 take offs on mine w/black wheel skins completely changed the look
wr20
Stuart fl
What is the brand of radio? I want to replace our CD + radio unit in our 04 eddie bauer
Frank Swygert
Gilbert, SC
Where did you find the Ford cross bars for the roof rack? Mine are missing (an 05 XLT) and I'd like to have some. It has the mount points on the side rails.
MasterX
MasterX
Arizona
Ebay, if you have the 05, you need part number 5L1Z-7855100-AAA : Here is the exact one i bought, their a ford dealer, and are even kind enough to verify fitment by Vin when you buy.
https://www.ebay.com/itm/273916682198
MasterX
MasterX
Arizona
This is the exact radio i have, i believe it was recently discontinued in favor of a newer model: https://www.amazon.com/gp/product/B07HQHCH65/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Here is the newer model, it is identical, but with newer firmware and android 9 now instead of 8, WARNING, do not cheap out and get the 2GB version, YOU WILL REGRET IT, 2GB is just not enough for it to be snappy.
https://www.amazon.com/KURATU-Andro...ds=kuratu&qid=1585809896&s=electronics&sr=1-4
And get this to port your rear USB ports on the Radio to your dash in a spot of your choosing!
https://www.amazon.com/gp/product/B01N66N1JK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
MasterX
MasterX
Arizona
As long as the wheels are not damaged, and still roll, they are fine, im not a fancy wheels guy.
Jb14
Looks good, I am doing some similar stuff getting ready to hand the truck over to my son. You got a great price on a new trans, I couple years back I lost OD and had rebuilt and cost me $1500 (would have preferred to drop in a new one) Enjoy
MasterX
MasterX
Arizona
New pic with the Gen 3 and Gen 2 side by side with matching push/ramming bumpers, and yes, those are solid steel, not the cheap look alikes
The red one is my 4x4 2005 5.4L 3V Heavy Towing Package Eddie Bauer with all the trimmings and customization's. This one goes offroad a lot, woods, lakes, rivers, canyons where we go shooting, etc.
The white one is a 2WD 2009 5.4L 3V Heavy Towing Package Eddie Bauer with all the trimmings but bone stock other than the armored bumper.
Kryo-Genik
El Paso TX
So you went from a 4r70w to a 4r75 and it was a direct drop in, bolt up that required no other modifications? Well if it drops right in....im gonna have to go find one....or I'll have a buddy of mine build my 4r70 balls out and call it good. If his setup lives behind a 2000 horse power Lightning itll live behind my family hauler lmao
MasterX
MasterX
Arizona
Im not sure where you saw that? Come again? Do you want to explain what you have, and what your trying to do there?
OK i did some reference, and you must have a 03 or 04 Expedition if you have a 4R70W, and you may not realize it, but it is quite different from my 2005. both 5.4, but not the same 5.4, not the same computer, and not the same transmission either...
If your in a 03-04 you have a 2V motor, with the 4R70W, with 40 HP less, and 15 tq less than 05+ as yours is a 2V motor(2 valve per cylinder), and mine is the newer more powerfull 3V motor(3 valve per cylinder), which also came with a newer transmission, the 4R75E.
I have essentially the same engine as a 2007+, but the 2007+ also got an even better transmission upgrade, the 6R80 which can be swapped into 2WD expeditions of 2003-2006, however its a lot of work.
https://en.wikipedia.org/wiki/Ford_Expedition#Powertrains
If you did decide to swap over to the new 6 speed transmission from a 2007+ you would need the following:
Third party transmission controller Kit (USSHIFT.com)
6R80 Ford version Transmission
SCT Handheld Tuner
A tuner who can turn off the ECU transmission controls and essentially program it for operation as a manual transmission system, this requires the handheld tuner.
Possibly a new custom length drive shaft.
possibly some other minor odds and ends.
Zach Dean
CA
I want to ask about the head unit you put in, does your truck have a DVD player and if so how was it affected by the new head unit, were you able to still use it and control the volume?
