Update all versions of Ford Sync 3 to the latest Sync 3.4
Super Moderator
Super Moderator
2020
Really, then you should have newer Firmware... You have Calm Mode under display settings?
We are missing something. I need to do some digging today!
carymccarr
Earth
Mine is 3.4 and yes, calm mode is there!
Lou Hamilton
That would be great! I just checked and I’m on version 3.4 and cant scroll to the next set of presets/favorites with steering wheel controls...when it gets to the end of the first 6 presets it goes back to the first one instead of moving to the next 6...
nor can I combine fm/xm stations. How are you performing those tasks?
Are you saying you need to program startup in forscan? Is there a specific black label startup? What does it say?
Thanks for all the info. Very helpful.
APIM
7D0-01-02 **** xxxx xxxx Brand: 0=Ford, 8=Lincoln, C=Configurable Splash Screen (This is actually for the theme)
APIM
7D0-02-01 xxxx x3xx xxxx Lincoln Black Label start-up screen124024_1__7f0809db504d14a5cdcae6fa716a9114052b145e.jpg
carymccarr
Earth
APIM
APIM
Wow bizarre. My BL has a navigator splash
carymccarr
Earth
Let me Double Check I can do that in the Expy. I definitely could do it in my Edge. I know I can do it in my 2020 Explorer ST, cause I set the presets yesterday. It is running 3.4.
Any chance you had a min to check yet? Thanks
Super Moderator
Super Moderator
Curious about moving from preset screen to preset screen from steering wheel buttons...thanks!
Sorry. Mine acted exactly the way yours did.
