2020
Really, then you should have newer Firmware... You have Calm Mode under display settings?
We are missing something. I need to do some digging today!
2020
That would be great! I just checked and I’m on version 3.4 and cant scroll to the next set of presets/favorites with steering wheel controls...when it gets to the end of the first 6 presets it goes back to the first one instead of moving to the next 6...
nor can I combine fm/xm stations. How are you performing those tasks?
Are you saying you need to program startup in forscan? Is there a specific black label startup? What does it say?
Thanks for all the info. Very helpful.
Let me Double Check I can do that in the Expy. I definitely could do it in my Edge. I know I can do it in my 2020 Explorer ST, cause I set the presets yesterday. It is running 3.4.
Any chance you had a min to check yet? Thanks
Already did! Post 297 above!
Curious about moving from preset screen to preset screen from steering wheel buttons...thanks!
Sorry. Mine acted exactly the way yours did.
But your edge and explorer could correct?
Yep!
That’s crazy isn’t it? Why would they essentially lower the functionality for their higher end vehicles?
It has to be a setting somewhere. Just need to find it!
Can you have the black Lincoln theme with out the Lincoln splash screen? I can’t seem to get mine out of the blueish purple theme. Thanks.
Shoot. I forgot one more change. Do these two things.
APIM
7D0-01-02 8*** xxxx xxxx
7D0-03-01 xxxx x3xx xxxx
This should only change the theme to the dark, but keep the Ford boot up splash screen. Your shutdown screen with be a generic Lincoln screen due to changing the theme to Lincoln, obviously.
Let’s put this stuff in a different thread please! We were talking the 3.4 Update. The BL splash screen is independent of the Update.
