Update all versions of Ford Sync 3 to the latest Sync 3.4
Moderator
2020
Really, then you should have newer Firmware... You have Calm Mode under display settings?
We are missing something. I need to do some digging today!
carymccarr
Earth
Mine is 3.4 and yes, calm mode is there!
Lou Hamilton
That would be great! I just checked and I’m on version 3.4 and cant scroll to the next set of presets/favorites with steering wheel controls...when it gets to the end of the first 6 presets it goes back to the first one instead of moving to the next 6...
nor can I combine fm/xm stations. How are you performing those tasks?
Are you saying you need to program startup in forscan? Is there a specific black label startup? What does it say?
Thanks for all the info. Very helpful.
APIM
7D0-01-02 **** xxxx xxxx Brand: 0=Ford, 8=Lincoln, C=Configurable Splash Screen (This is actually for the theme)
APIM
7D0-02-01 xxxx x3xx xxxx Lincoln Black Label start-up screen124024_1__7f0809db504d14a5cdcae6fa716a9114052b145e.jpg
carymccarr
Earth
APIM
APIM
Wow bizarre. My BL has a navigator splash
carymccarr
Earth
Let me Double Check I can do that in the Expy. I definitely could do it in my Edge. I know I can do it in my 2020 Explorer ST, cause I set the presets yesterday. It is running 3.4.
Any chance you had a min to check yet? Thanks
Moderator
Curious about moving from preset screen to preset screen from steering wheel buttons...thanks!
Sorry. Mine acted exactly the way yours did.
Moderator
That’s crazy isn’t it? Why would they essentially lower the functionality for their higher end vehicles?
It has to be a setting somewhere. Just need to find it!
carymccarr
Earth
Well, if anyone figures this out make sure to post!
Fozzy
Riverton
APIM
APIM
Can you have the black Lincoln theme with out the Lincoln splash screen? I can’t seem to get mine out of the blueish purple theme. Thanks.
Lou Hamilton
Shoot. I forgot one more change. Do these two things.
APIM
7D0-01-02 8*** xxxx xxxx
7D0-03-01 xxxx x3xx xxxx
This should only change the theme to the dark, but keep the Ford boot up splash screen. Your shutdown screen with be a generic Lincoln screen due to changing the theme to Lincoln, obviously.
carymccarr
Earth
APIM
Any 2020 black label owners out there that actually have the ‘black label’ splash? Mine just says navigator....?
Moderator
Let’s put this stuff in a different thread please! We were talking the 3.4 Update. The BL splash screen is independent of the Update.
carymccarr
Earth
Fair.
Ok. Anyone with a black label that updated to 3.4 have their BL screen change to the ‘navigator’ screen?
Anyone experience any changes to their black splash with the 3.4 update?
3.4, 3.4.
3.4
