5.4L Triton timing set, replace oil pump?
Langer
Chicago
Ok guys so I’m in for a new drivers side head. DO NOT try putting the cams in with rockers in place. I can hear it shredding the cam towers under the drivers side valve cover once running. I’m sure the head is full of metal shavings. I’m too pissed off/upset to get into it today....just going to walk away for now. All rockers were properly in place and cams torqued to specs once tightened then I loosened and did each cap separately with the torque wrench so I could get proper torque.
Now I may sell the truck as a fixer upper and go put a down payment on a Suburban or something. Not sure I want this headache with the engine full of metal shavings. This engine has turned out to be a royal piece of dog sh*t. Walking away from Ford pretty much for good after this.....yes I made mistakes but they made service a living Hell. Something I refuse to own until I can purchase brand new and let the dealer do my maintenance. Going to take a break from this site and collect my thoughts, I may not be back.....at this point I think I’m dumping this truck off for an 07-10ish Suburban. Going to scour the lots today.
I’m sincerely sorry to hear this has turned into such a bear for you. It’s been inspiring to watch you try to tackle this project. After you cool off from the frustration, best of luck with whatever your decision is. If you do leave, never to be heard from again, have a good life, you seem like a pretty good dude.
Cheers
Frank Wilson
PlymouthMA
Don't throw it in now. Investigate. We are all watching and pulling for you. Youre still ahead of the game.
I took a nice long drive in my dads F-250 he’s given me while this repair is going on. He stopped in/called me that he started it and ran it a long time and said it starts billowing rubber smoke out from under the hood. He thinks my power steering pump locked up. He said the steering is tight and the noise varies with steering input and that the belt is totally smoked. He said I have it routed correctly so it can’t be the belt.
Im going down to the marina to work on my little boat to de-stress. It’s much easier to wax on wax off. I’ll come back to this one more time tomorrow.
07navi
Mt.Shasta California
So it's just the power steering? Buying another brand is a bad idea, you are still ahead of the game. Ford is NOT the problem.
I’m back with it now. The steering is very tight and the noise gets louder when I spin the steering wheel. It will go away entirely for a few seconds then come back depending where the wheel is at. Is there a bleeding procedure for this pump or do we think she’s shot?
I popped the cap and turned the wheel lock to lock and it’s helping but here is the next dilemma. The truck runs great for about 2 minutes then shakes, bogs out and stalls. I can’t keep it running. When it’s cold it’s running perfect. The smoke wasn’t the belt he was wrong, it’s the oil burning off of the exhaust manifolds because it subsided after a while.
The prognosis seems to be it jumped time again and is over-retarded on one bank...this fricking engine will not stay in time once you crank it jumps timing every time. going to tear the engine down one more time and replace the chains this time. Maybe in a few weeks, just keeping my dads F-250 for the foreseeable future.
My only other idea is possibly a VCT solenoid.
07navi
If you got it all together right it didn't jump time and it's not the chain. Did you put all the cam bearing caps back in the same place? You will know more when you pull the valve covers. Don't buy a Chevy because when that breaks down you will have to buy a dodge...….and then back to ford.
07navi
We are thinking an old chain is stretched a tooth or two...hence why my timing arks don't line up the way the Ford workbook shows when i have all the colored links lined up. Everyone says its acting over-retarded on one or both banks. Engine wont't run long enough (more than 2 minutes) to set a code. All cam caps kept in order and installed in same spots. Pulling valve covers isnt going to tell me anything frankly, its what is under the timing cover that makes this condition occur. When i get back home I'm going to unplug both VCT solenoids to see if itll run, if it does then we know it needs new camphasers.
I wish i just lived with the startup rattle and didn't do this...at least my truck ran perfect without a hiccup before. There wasnt much damage, all these youtube mechanics blow the startup rattle out of proportion i could have left it alone rattled for a year and no damage inside at all.
That's why it's good to have a real pressure gauge. The phasers were good before so that's not it, and it's not the chain because it didn't jump a tooth even with the bad tensioner. Chains don't suddenly wear out and they rarely do wear at all. Don't just throw parts at it, find out what happened.
Got the scanner on even though there was no CEL and the only computer code is a vacuum leak. I don’t think that has anything to do with my rough idle and stalling though. There should be camshaft position sensor codes for over-retard. Runs perfect until it is warm.
No difference with VCT solenoids unplugged same deal, runs good for about 2 minutes then starts to surge and dies.
Might be OK then, a vacuum leak would cause that.
It seems the brake booster line is off at the back of the intake manifold. Installing the drivers valve cover likely knocked it off. I’ll pull the intake manifold out Monday because I can’t reach it by hand.
07navi
That's a lot of vacuum loss right there. Things that are acting up on engines make them act in strange ways which makes them hard to diagnose unless you work on them every day.
