What is this noise on start up?
effingpot
Hampshire, England
When I start my Expedition for the first time each day - about 5 seconds in, it makes this huge grinding noise, like something moves (badly) but is having a problem. Not living in the US means I can't just get the Ford guy to take a look. I videod it this morning - the grinding sound is at 5 secs.
This only happens the first start each day. Other times in the day it seems fine.
Any ideas?
thanks
Mike
Shantheman73
Kansas City
Any ideas?
thanks
Mike
That sounds like your a/c compressor kicking in.
Turn off your HVAC system tomorrow morning before starting it and it prob won’t make that noise.
Mine has been making same noise lately and I recently had ford replace the compressor which ticks me off. I took it to them and told them to replace it again. Naturally they need to keep it overnight so they can hear the sound in the morning. I’m gonna make another appt.
Hope this helps!
2007 Ford Expedition Limited
07navi
Mt.Shasta California
I think you need a new ac pump, notice how when it kicks on it puts a drag on the serpentine and flexes the tensioner. (watch belt tensioner). If you don't have a set of ac gauges you need them to check high and low pressures. Did you recently add refrigerant? Too much will "slug" the compressor and cause that noise.
effingpot
effingpot
Hampshire, England
OK so looks like you guys are correct. This morning, with the airconn switched off the engine started normally with no crunching sound. In fact, looking at that video again (above) you can see the little arm (or whatever it is) behind the cable vibrating as the noise happens. Not being a car techy can I ask in plain simple English what is actually happening at that point? I get it that the Airconn compressor is engaging but what does that translate into? Is somethign physicall moving? How do we work out what to do next?
Thanks
MDSavage
HOLD ON...DON'T SPEND ANY MONEY!
I have owned our 2014 5.4 Expedition from new. The vehicle has made this noise from new. Shortly after purchasing I took it to the dealer to fix it. Sounded like a trans / internal noise to me. Yes it would only do it on a cold start. Ford told the dealer to replace valve body, front pump, then they told them to find a similar vehicle on the lot to compare the noise. Heck, those engineers didn't know what to noise was either. I was going to turn the car in under our lemon laws here in Maryland until a person on the site here explained what was going on.
In 2014 Expys with a 5.4 the ac compressor is mounted low. After a long sit the refrigerant oil will lay in the compressor and if it isn't pushed up it can blow seals. The CASS system does this push when the system initially is turned on. I always leave the hvac on so the first thing each morning you hear the grinding like noise. The noise actually is the ac line rattling I believe. A quick test is to turn off the hvac the end of the day. Start up in the morning (no hvac) and drive a couple miles. Stop and put on the hvac. You should then hear the freaking noise. We have had the expy 5 years now with no problem. But, the noise still happens on a stone cold start.
In my opinion Ford knew about the problem and put it off in 2014 since they were going to EcoBoost in 2015.
Good luck but our dealer did a bunch of fixes to eliminate the noise. I still laugh with the service manager when we take the expy in for free oil changes under a customer for life plan.
07navi
Thanks
The spring loaded wheel that pushes on the belt to keep it tight moves briefly in and out when the compressor tries to lock up due to being overloaded with liquid refrigerant (slugged) and pulls harder on the belt momentarily.
07navi
From a 2014 post from sambo in this forum:
Air conditioner compressor noise
The noise you hear from the a/c compressor when it is first turned on is caused by where the compressor is located. I bought a new 2004 Ex pedition and it made this noise Ford calls (get this) CHUGGLE. I brought the truck back to the dealer so many times and was a pain in thier ass they finally printed out the service bulletin. It said "this cannot be repaired if you try to repair it, it will still make this chuggle sound and Ford will not reimburse you for the work if its under warrenty". The sound is caused by the liquid refrigerant and oil collecting in the compressor under certain conditions. Because the compressor is the lowest point in the system, poor engineering. The shop manual addresses this issue, in the manual its called "slugging". Ford was supposed to program the ECM to engage the compressor clutch while the engine is cranking to push out the liquid and oil slowly. Apparently this doesn't work. the dealer said this "will not hurt the compressor". I just retired after being an auto and truck mechanic for 47 years and this is BS the compressor is very delicate and won't take that for too long. It happens when the sun heats up the interior of the car causing the gas in the a/c system to expand forcing the liquid into the compressor if you notice this don't happen at night or in colder weather. To prevent it and save the compressor shut off the a/c before you park the car for several hours, when you restart the car DON'T turn on the a/c until the engine has fully warmed up, about 5 minutes. Hope this helps
akacolonel
chicago
My 2014 expy has done this since I bought it in 2015 with 40k miles on it. I didnt think it was the cam phasers, so wasnt too worried. Recently, out of boredom, determined it was a/c compressor engaging. But I didnt think about it being mounted low, and pag oil would settle. There are some sharp guys on this site.. thanx guys!!
effingpot
effingpot
Hampshire, England
Super - thank you very much. I'm gonna go with the keeping the AC off option as a) it's cheaper, b) it's easy and c) I live in England so who needs AC anyway :) haha! (Mind you we are getting summer temps these days in Feb so maybe we do need AC!)
Shantheman73
Kansas City
I’m curious if you or anyone has the service bulletin addressing this?
07navi
There is only supposed to be refrigerant (Freon) in a gas form inside the compressor at all times. If liquid refrigerant or an excess of oil settles in there while sitting it will choke on it until it passes as long as it passes quickly, if not quickly it will ruin the compressor. Too much refrigerant or too much pag oil can cause this, so get the gauges and check it out.
BlueStangGT
Oklahoma
I went through the same thing last year when I bought my '14 Limited. It had previously been sold as CPO vehicle and thus had a 100k powertrain coverage so I wanted to make sure that any issues were addressed before the 100k was reached. I couldn't identify this sound and, after several trips to my Ford dealer and conferences with the Shop Manager, we concluded that this was the same "slugging" that you and many others here have experienced.
Shantheman73
Kansas City
Did they replace anything or just tell you it’s normal?
07navi
Definitely not normal and it will grenade the compressor if it can't spit out the liquid quickly enough and they are expensive. I slugged my last truck when I put too much refrigerant in it, it locked up, and the belt was squealing but luckily it spit out the liquid soon enough. Another few seconds of that would have cost me $500 +-. Other parts in the system can determine whether the refrigerant enters the compressor in a gas state like it's supposed to or not, besides overfilling.
akacolonel
chicago
07navi made a good point. I shut my a/c off when I park truck. Next morning I Wait for a few minutes after initial startup then turn on a/c, and no noise.. good call!
BlueStangGT
Oklahoma
Nope, didn't replace anything as the AC was and is working like a champ. I honestly don't recall the word "normal" being tossed around although we did conclude that it's not unusual. I specifically asked him if he was comfortable with a vehicle making this noise and he said yes. We were also working with one of his line mechanics who's experienced the same issue. All this was going on around the 99k mileage mark and now my Expy has about 104k. Neither my '05 2WD XLT or my '07 4WD XLT exhibited this noise which is what really had me spooked to begin with.
effingpot
effingpot
Hampshire, England
So the car is for that paint job in the other post and the garage have this post to read too.
They are saying why not just refresh the AC system, suck out the old stuff and replace with new. Will that do any harm or good?
07navi
You could but it won't cure the problem. It sounds like a bad orifice tube or expansion valve depending which one the vehicle has. The refrigerant needs to be in a complete gaseous state when going though the compressor.
We replaced everything with new OEM components on my last 2007 that had slugging problems after the compressor clutch seized. New compressor, new tube, new filter drier and new refrigerant with correct pressures and it still slugged. My dad owns a refrigeration business and has large accounts such as Pizza Hut and he did the charging when I finished the job. He also flushed the system. Common issue on these trucks and it’s the oil collecting where it shouldn’t. Warm up the engine then it won’t happen because the liquid will move away from the compressor. They sell desluggers as well that rapidly cycle the compressor to ease liquid past the valves. The problem is valves aren’t made to fight compressed liquid, same as your engine. They can bend and lock up or just slowly wear out due to the slugging.
If anything you’d have to try a flush and a new charge since it’s excessive oil.
jtebbe0529
