Well, did some reading on the P0442, small Evap leak, a few folks (including the dealer said put a new gas cap on it and that should fix it. I didn't buy one from them.
It happened about a year ago and the new cap eliminated the code, but the gremlin is back.
I did replace with a new Stant at the time.
In the meantime I'm ordering:
https://www.fordpartsgiant.com/part...080&Filter=()&Location=engine/fuel_tank,,9030
Ford Part No.: XU5Z-9030-MA
Cap Assembly - Fuel Tank Filler
Base No. 9030
Part Description Cap Assy - Fuel Tank Filler
Manufacturer Ford. This genuine Ford part is guaranteed by Ford's factory warranty.
If this new cap is not the cure, any recommendations?
I was wondering if anyone did a bypass of the canister? I'm not sure yet if that is it, but if the bypass works I can R/R the can, or just remove and do a charcoal replacement and JB weld the container back together. I think there's also a method to blow compressed air on the downstream tube to agitate it up and 'clear' it out. If the can is the issue would a bypass be a good test???
I never overfill the gas tank, rarely go to the shut off on the pump, just guess how much to get close to a full tank - usually pretty close.
I have an inspection due by the end of June. They only plug their machine to the OBD and check tires, wipers, leak test on gas cap etc. No real 'inspection' or sniff test like CA.
Please let me know your thoughts.
Base No. 9030
