Got my light mounts in...
Now to find some lights. I had ordered a used set of KC Flex on Amazon but the seller cancelled the order for some reason. I like how low profile the dual flex setup is...
Installed AMP Research power running boards. Very impressed so far! Incredibly well made. They tuck up under nicely and give it a really clean look.
@CE750 That's a good looking ride. I did Bilsteins on the front only, lowest settings I believe, just to level it. I'm considering adding the rears and would like to get an extra 1" or so there to have a slight rake, which would help out when loaded down or pulling a trailer. For some reason I didn't think the rears were adjustable, but I saw someone (maybe you?) mentioned it.
Do you know if the rear Bilsteins would give me that 1" without any additional equipment (spacers, etc)? And do you know if there is an adjustment component to the rears? I thought it was a fixed shock, unlike the front which is more of a strut with the three settings.
Yes the rears are adjustable as well. Mine are set on the highest ring and I ended up with around 2" of lift. You could set them on a lower setting to achieve the 1" your looking for.
Can you only do 72 month term? I would assume so since the longer the term the less impact waiving 3 months has...?
