2007 EL with 370k miles. Took it in for the following reasons: transmission/engine (not sure which) shuttering in the 30-40mph range. There was also an occasional cylinder 1 misfire - compression fine and plug/coil pack no issue. Somewhat rough-ish idle, nothing extreme.
Anyway, the mechanic pulled out this part which was loose in the engine.
Does anyone know what it is or what it may have come off from? The mechanic and I are mystified how the engine can run (relatively well).
Thanks in advance!
Thanks in advance!
