1999 Ford Expedition No Start No Crank - Electrical Issues
Zebani S
New Orleans, LA
So I lent my Expedition to a friend, he went on short trip to the gas station for cigs, no problem, got home shut it off, then tried to turn it back on and nothing. Thought it needed a jump, but it still wouldn't start. I took at a look at it and when I would switch it to start, the headlights and all the lights on the dash would kill and not come back. The door ajar sound would be the only thing that would work. Then at random times, the dash lights and headlights would come back and behave normally but the vehicle still would not start and after attempting the dashlights and everything would kill again.
I've had a lot going on so it's just been sitting for the past three months or so. Occasionally I take a look at it and try to get it running but no luck. Currently it's not doing the dash thing anymore, everything else electrical is working fine, the power locks, the headlights, the dash, etc. But still it won't crank. Here's what I've checked and done so far:
Cleaned the battery terminals
Checked for blown fuses
Checked relays for signs of corrosion
Tried two different fully charged and load tested batteries
Jumped the starter (and yes it's responsive)
Changed the ignition switch
Any help would be greatly appreciated! Thank you
Yupster Dog
Moderator
voltage drop test the battery cables. check ground connection on other end of cable. Sometimes the corrosion can be under the insulation on the cable
docraymund
philippines
Yes definitely a problem on battery cables. Check the cable to terminal connection for looseness or corrosion. Also check the connection at the starter itself.
Z
Zebani S
New Orleans, LA
Ok so I didn't know these Xs have two starter solenoids. After cleaning the connections on the starter (already did the battery connections weeks ago), I took a jumper wire and jumped the solenoid that's under the hood and lo and behold the starter engaged. So that means this remote solenoid isn't getting signal right? Do I maybe have a bad neutral safety switch? My shifter is out of alignment but I made sure multiple times I was in park and even walked down to neutral to see if it would start then but still a no.
craig sargood
Is the alarm light on the dash flashing at all?? Had an old 99 die at the store before, pcm fried and needed to be replaced and reflashed out of nowhere.
Josh_913
Las Vegas
But I keep reading that if the NSS is bad it should still start when I shift into neutral. But it doesn't.
This is true sometimes but more often than not when a NSS fails it wont start in either. I would also suggest trying to make sure other electrical components work when the battery is on (ie: horn, lights turn signals high beams) that'll tell you if its the NSS or the another electrical problem somewhere
Z
Zebani S
New Orleans, LA
Thank you. For now I'm wiring up a push start button to the under the hood solenoid cuz I don't have time to hunt this down.
docraymund
philippines
Yes same here after sitting for almost 5 months my 2000 expy won't crank. Thought it was the battery (more than 6 years old) but still retains charge. Tightened battery cable wire connectors more and it cranked! Now, problem is it won't run. Am testing fuel pump circuit. At least yours is driveable although you need to pop the hood Everytime. Try testing the starter solenoid under the hood. Good luck!
Z
Zebani S
New Orleans, LA
Ugh, don't you just love multiple problems layered atop each other? I hope you get it running soon.
The solenoid seems to be totally fine. It clearly was not getting signal. I hooked up the multimeter to the signal wire and put the ignition in run, and all that's coming from it is a steady 3+ volts regardless of whether the ignition is in run or not. And with total reliability if I put 12v to the signal post on the solenoid she fires right up. So the solenoid is good. For some reason the signal wire is putting out voltage even when ignition is not in run, but not 12v. Clear sign of a short, yes?
docraymund
philippines
Yes, it should only have 12 volts on start going to the solenoid. You need to do some wire tracing.
rjdelp7
2000 XLT
NY
Shift into neutral and try starting. Your problem reminded me of the scene in 'Christine'. Arnie sweet talks it into starting.
Z
Zebani S
New Orleans, LA
Read up, that's already been explored friend. Thank you though. It doesn't start like that no matter what gear I'm in or if I rock the shifter. Shifter is definitely sloppy af, so who knows it could still be a faulty NSS but I don't feel like replacing it rn. Also, the signal wire to the solenoid should not have voltage unless the key is in run position (and then it should be 12v), yet it's putting out 3+ volts constantly. So at the very least there would seem to be a short in the ignition wiring.
brhulen
Olympia, WA
What about the GEM? My 97 has now been sitting for about a year with the same problem. Also mine has a history of failed GEM x 2.
