Adaptive Suspension and Towing
Jpfeifer99
Denver
I recently purchased a 2019 max with tow Package and adaptive suspension. I tow a lot and was planning to install a weight distribution hitch but the hitch store says I don’t need it if I have the adaptive/air suspension. Does anyone know if the adaptive suspension will level the car with a trailer?
I cannot find any information stating it will do this, everything I read /watch only says the suspension changes based on raid terrain?
Thanks for any info you may have on this!
Wayne Decker
New York State
IT will not level the vehicle. You need a WD hitch (if you needed it with your previous vehicle and this thrailer).
The adaptive suspension stiffens and loosens things but doesn't raise or lower them.
shane_th_ee
Seattle
More important is that air suspension systems, air bags, helper springs, etc, etc do NOT put weight back on the front ("steer") axle. Shifting the tongue weight off the rear axle and onto the front axle is what a WDH does. And of course, you're limited to only a 600lb tongue weight unless you use a WDH...
ChaseM
Logan, Utah
A good weight distribution hitch like the Equal-i-zer brand not only keeps your back end from squatting, but also does sway control. Even with airbags, I would still recommend the hitch for the sway control. A good hitch makes all the difference when towing.
Greg Parker
Arizona
...and if you want the BEST possible system out there (which it sounds like you do, if you're towing that often) ....this bugger is on my list. I will get it eventually, especially if I go beyond 700# tongue weight and 7500# GVWR.
NOT cheap, but the most well-reviewed and stable towing platform anywhere. I have two friends that have them and based on their feedback, they are 5-7x better than the $400-$600 WDH's from most other vendors.
https://store-b8894.mybigcommerce.com/propride-3p-trailer-sway-control-hitch/
dlcorbett
Air Force
tx
Im surprised noone corrected you, the expedition does not have air suspension or technically a real adaptive suspension. The ccd uses coil springs and "adjustable" dampers that can change the driving capabilities of the car. Its not adaptive as it does not change on its own, you have to change it. The navigators suspension can change on its own i believe if you leave it in normal, but the expeditions doesnt. As far as towing goes, the vehicle doesnt have load leveling at all (weird its still not available as even an opt), but i believe tow mode in the drive cntrl settings stiffens the rear a bit.
dlcorbett
Air Force
tx
Sorry im was wrong, expy and navi have adaptive suspension, not active suspension. I was thinking active suspension.
J
Jpfeifer99
Denver
Well ford calls it (CCD) Adaptive Suspension which is likely causing confusion.
Deadman
There is no airbags on these, so no weight support for a heavy trailer.
wingrider
Calif.
Every time I start thinking again about a new Expy, Comments like this remind me how much I appreciate the factory rear suspension air on my 2012. I just towed my shared 24' enclosed car trailer loaded to/from a 2 day track weekend and it just tows so well.
I want to give them money but they are making it tough. Guess those of us who tow are not enough of a market- just like no factory option trailer mirrors that exist for F-150s. Darn you Ford.
Deadman
The air shocks were notorious for failures. Lines crack, lines get ripped off my branches, bags rot from age and heat. Then there's only a few airbag shocks to pick from on the market. I'm pretty sure Ford did right by letting the bags off. Sumo springs are easily added if needed.
wingrider
Calif.
I don't hard core off road that I'd catch a line on something. I'm fortunate that my '99 had no air system issues except replacing the compressor at about the 10 year mark. My '12 has had no issues so far but to me, it's like other things like shocks and struts so replacing them is a maintenance item. The Ford product is fine for me as a replacement when it comes. My '12 uses the same bags as the newer years so I should be fine for a little longer.
Deadman
Right, but shock technology has come a long way since then, so the new ones perform a lot better and are computer controlled on the premium models. They rode like they are on a cloud now.
MAC1
Chester County, PA
I agree with this wholeheartedly, I started with an equalizer on my 2016 EXPD., pulling my 24' ATC Quest 305 Aluminum trailer. I was ready to sell the trailer and give up on towing until I bought the ProPride hitch. Completely eliminated my sway problem; I have gone from 50 mph white knuckle driving to 70-75mph, with no issues. It makes the trailer behave like it's on a fifth wheel hitch; it's expensive, but well worth it, IMO.
lurch
Boulder, CO
This 1000%, the hitch store does not know what they are talking about. This is WDH 101 stuff, I would find another hitch store.
Ben Scrace
WA
I have a 33’ travel trailer with WDH. I would like to add something to help with the droopies in the rear. What is recommended as aftermarket addition?
Wayne Decker
New York State
If the tongue weight of your trailer is within limits of the vehicle, just adjust your WD hitch to level things out..
mwl001
Scottsdale AZ
Visit a scale. If your hitch is adjusted properly you should have very little if any sag.
I'll second this - I haven't been able to get a tongue weight on my trailer yet, but we've towed as much as 5500lbs based on the trailer axles, and when my WDH is calibrated I get 1/2-3/4" of sag at most. Fixing that imbalance is going to do more to improve handling than anything else you might add or replace afterwards.
Something else to check is hitch height. I needed a pretty serious drop to get my trailer close to level. Before correcting that, it was basically impossible to redistribute the trailer weight without tipping the trailer towards the back and taking too much weight off the tongue. That's really step one before you can dial in the WDH.
