We need a bigger dataset? ...I mean, if the OPS is dropping off during a long AS/S stoplight, then this seems like a pretty simple explanation. I assume that there's some level of programming involved and the newer (or older?) flashes might keep the "running" pressures active over the auto-stop pressures. The bottom line is if you see the pressure drop AND the RPMs drop to zero, it's the AS/S.
(Mine rarely, if ever, engages in the current 100F+ temps of the desert Southwest right now. I have had the AS/S engage ONCE since I drove this bugger from Wyoming back to Arizona a month ago. I'm sure it will kick-in again once the ambient air-temps in the PHX area drop back into the double-digits.)
